[Qgis-user] R scripts not running in Windows
Victor Olaya
volayaf at gmail.com
Thu Feb 13 09:46:49 PST 2014
Seems like the check that is performed before staring and R algorithm
is failing. Do you have R correctly configured (in windows you have to
specify the path to R in the config dialog)
Not sure about the issue with the plots. The file referenced in that
HTML snippet...does is exist? is is created by R? The output of the R
execution is saved to a .Rout file in the ~/.qgis2/processing folder.
You can check there to see what is happening.
2014-02-13 17:02 GMT+01:00 Ned Horning <horning at amnh.org>:
> I am able to execute R scripts using the Processing plugin on my Ubuntu
> computer simply by double-clicking on the script name or selecting "Execute"
> from the script's menu but in Windows 7 when I try that I get an error
> "Missing dependency. This algorithm cannot be run". For some reason the same
> script works fine if I run it from the Script editor.
> Another issue I have with Windows 7 is that plots are not being displayed.
> For example, when I run the "Raster histogram" script that is part of the
> Processing examples on Windows 7 a plot is not displayed. Instead this
> appears in the Results window: <img
> src="C:/Users/Ned/AppData/Local/Temp/processing/a8531c28f8aa4196ae5a56037efa8f87/RPLOTS.html.png"/>.
> This works just fine on my Ubuntu computer.
> Any ideas what the problem might be?
> Ned
> Qgis-user mailing list
