[Qgis-user] edit polygon point jumps uncontrollably
Olivier Dalang olivier.dalang at gmail.com
Thu Feb 13 13:09:35 PST 2014
Are you using the latest build ? I had similar problems a few days ago, but
now it seems it has been resolved...
2014-02-13 21:08 GMT+01:00 Jake Maier <j.m at jmforestry.com>:
> I just loaded the same file into 2.0.1 and no problem moving the point
> around. Before I tried whatever I could think of and it did not work but
> put
> the point way off into the distance.
> Any suggestions?
> Jake
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Paolo Cavallini
> Sent: Thursday, February 13, 2014 1:24 AM
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] edit polygon point jumps uncontrollably
> Il 12/02/2014 17:43, Jake Maier ha scritto:
> > In 2.1 master, when I edit a polygon layer I can move a point to the
> > location I intend  but as soon as I release the mouse button, the
> > point jumps outside of the canvas, and sometime way outside meaning
> > the lines to the point are about parallel.
> > I had this behavior occasionally also with previous versions of QGIS
> > but now in 2.1 it seems persistent.
> > What can I do?
> UNconfirmed here.
> Silly question:
> Have you checked you do not have a too large snapping (e.g. in degees)?
> all the best.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140213/f0ddcf38/attachment.html>
