[Qgis-user] edit polygon point jumps uncontrollably
Jake Maier j.m at jmforestry.com
Fri Feb 14 07:35:39 PST 2014
Loading the newest version did solve the problem Thank you very much
Jake
From: Olivier Dalang [mailto:olivier.dalang at gmail.com]
Sent: Thursday, February 13, 2014 4:10 PM
To: Jake Maier
Cc: qgis-user
Subject: Re: [Qgis-user] edit polygon point jumps uncontrollably
Are you using the latest build ? I had similar problems a few days ago, but now it seems it has been resolved...
2014-02-13 21:08 GMT+01:00 Jake Maier <j.m at jmforestry.com>:
I just loaded the same file into 2.0.1 and no problem moving the point
around. Before I tried whatever I could think of and it did not work but put
the point way off into the distance.
Any suggestions?
Jake
-----Original Message-----
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Paolo Cavallini
Sent: Thursday, February 13, 2014 1:24 AM
To: qgis-user at lists.osgeo.org
Il 12/02/2014 17:43, Jake Maier ha scritto:
> In 2.1 master, when I edit a polygon layer I can move a point to the
> location I intend  but as soon as I release the mouse button, the
> point jumps outside of the canvas, and sometime way outside meaning
> the lines to the point are about parallel.
> I had this behavior occasionally also with previous versions of QGIS
> but now in 2.1 it seems persistent.
> What can I do?
UNconfirmed here.
Silly question:
Have you checked you do not have a too large snapping (e.g. in degees)?
all the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140214/832e7bce/attachment.html>
