[Qgis-user] layer prorieties crash
Eugenio eugenio.fasser at gmail.com
Tue Feb 18 06:07:03 PST 2014
Where Do I find crash log?
I have found bug 9570:
Opening Layer -> Properties 12 times crashes QGIS master
It is very similar
Il 18/02/2014 13:14, Jonathan Moules ha scritto:
> Wow, that sounds very bad. I'd suggest opening a ticket on the QGIS
> tracker with as many details as you can including exact process to
> reproduce it and any crash log if there is one.
> Jonathan
> On 18 February 2014 08:50, Eugenio <eugenio.fasser at gmail.com
> <mailto:eugenio.fasser at gmail.com>> wrote:
>     hi,
>     qgis 2.0.1 on ubuntu 13:10,
>     when I open the Layer Properties (vectors only) the pc crashes,
>     I tried to reinstall qgis,but problem remains
>     What to do?
>     thanks
>     Eugenio
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-user
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> it, or disclose it to anyone else. If you have received this
> transmission in error please notify the sender immediately. All email
> traffic sent to or from us, including without limitation all GCSX
> traffic, may be subject to recording and/or monitoring in accordance
> with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140218/d2b5de49/attachment.html>
