[Qgis-user] Can some one help me to convert a .bil file in a shape file?
NYA Edouard
edouardnya at gmail.com
Tue Feb 18 15:13:27 PST 2014
Thank you for the try. I already tried this way with no succes. Since
yesterday, I launch a try and till now, I have no result (4G RAM, 3,2
Ghz). The thing takes too long.
Still looking for solutions,
NYA
2014-02-18 1:40 UTC+01:00, Etienne Tourigny <etourigny.dev at gmail.com>:
> On Mon, Feb 17, 2014 at 8:32 PM, Saulteau Don <sault.don at gmail.com> wrote:
>> On 2/17/2014 3:55 PM, NYA Edouard wrote:
>>> The bil file es very heavy (more than 1800 MB), so I need to convert
>>> the file so that I can trim it easily to process it for the project.
>>> Any idea?
>>> Thanks in advance
>> You can use gdalwarp from the raster menu to convert the image to
>> whatever
>> format you need, reproject it, and also clip it all in one step.
>> If the gui isn't self explanatory, see the full suite of options at
>> http://www.gdal.org/gdalwarp.html You can manually input any of those in
>> the bottom of the gdalwarp gui.
>> To make things really easy, you don't even have to extract the zip and
>> decompress the bil file (takes a long time!).
>> You can manually input the bil file to make use of vsizip with something
>> like "/vsizip/HWSD_RASTER.zip/hwsd.bil" This would read the dataset from
>> within the zip file instead of from on disk somewhere.
> qgis now supports rasters inside .zip files transparently
>> Donovan
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
