[Qgis-user] Project not loading in web client
Voytek Lapinski
voytekl at octobit.com.au
Wed Feb 19 15:16:07 PST 2014
Opened as issue http://hub.qgis.org/issues/9605
-voytek
On 19/02/14 18:59, Andreas Neumann wrote:
> Hi Voytek,
> In my opinion this is a bug in QGIS server - if it generates a
> GetCapabilities or GetProjectSettings response, but no GetMap. Can you
> please open an issue?
> If the "Service Capabilities" is checked off, QGIS server should just
> issue an error message that the service is not available. In that case
> we could even display an error message in QGIS Web Client if the service
> is not available.
> I just tested it and can confirm that the GetCapabilities is still
> issued even if the checkbox is not turned on. This is a bug in my opinion.
> Andreas
>> The problem with the map not loading was being caused by not having the
>> "Service Capabilities" box checked in Project Properties/OWS Server.
>> Once that's turned on, the project loads fine in the web client (albeit
>> with other issues unless the CRS stuff is sorted out also). Rookie
>> mistake, obviously.
>> Thanks again.
>> -voytek
> Qgis-user mailing list
> http://lists.osgeo.org/mailman/listinfo/qgis-
