[Qgis-user] Spatialite VIEW in QGIS question
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Thu Feb 20 10:34:26 PST 2014
Am 20.02.2014 18:13, schrieb Olivier Dalang:
> Bernd,
> Here's a procedure which works here on QGIS master :
> 1. Create a spatialite layer "countries" with fields "name" and a
> geometry column "geom" of type polygon.
> 2. Add some features to that layer.
> 3. In the DB manager, create the view:
> CREATE VIEW countries_influence AS
> SELECT rowid as rowid, name, Buffer(geom,1) as geom FROM countries
> 4. In the DB manager, register the view:
> INSERT INTO views_geometry_columns VALUES
> ('countries_influence','geom','rowid','countries','geom',1)
> 5. Reload the database in the DB manager and right-click : "add to the
> canvas".... It does NOT work.
> 6. From the "layer" menu, choose "add a spatialite layer", navigate to
> your db, choose the view, and, tadaaam, it WORKS !
> Let me know if it works...
> It seems the bugs comes from that "add to the canvas" function, which
> sets the source to
> path/SpatialiteView.sqlite' table="countries_influence" () sql=
> instead of
> path/SpatialiteView.sqlite' table="countries_influence" (geom) sql=
> Regards,
> Olivier
Hi Olivier,
thank you for trying to help,
but, ermm, actually I do not see the point performing this. I have not
really a problem creating views, but more making these functional in
QGIS. Your example, as far as i understand, lacks a join-part
completely, but thats the culprit I fear.
I uploaded my testdb to dropbox.
https://www.dropbox.com/s/8b1g97qu3us15tq/asktest3.sqlite
There is only layer, a view and the table.
Could anyone try it out?
When you query the view with SELECT * FROM "Testview22" , I see the list
of observation I would like also to see in the QGIS attribute table, but
this just doesn't work. It also show 746 rows, but only 37 distinct sets
of information.
Cheers
Bernd
> 2014-02-20 16:51 GMT+01:00 Bernd Vogelgesang <bernd.vogelgesang at gmx.de
> <mailto:bernd.vogelgesang at gmx.de>>:
> > Am 19.02.2014 20:02, schrieb Olivier Dalang:
> > Dear Bernd,
> > I encountered some similar problems with Spatialite views, but in
> the end I had it working (sometimes) both in 2.0 and in master... I
> used the manual method from the spatialite cookbook though (not the
> Spatialite GUI).
> > I have no time to test now, but from what I recall, this does not work :
> > CREATE VIEW AS SELECT name, geometry FROM table
> > while this works :
> > CREATE VIEW AS SELECT ROWID, name, geometry FROM table
> > Maybe you want to give it a last try. I can testify I have some
> working spatialite views here. Let us know if this works, if not I may
> give it a better look when I have some time.
> > Another method is running a SELECT query in the DB Manager in QGIS,
> and then choosing "Add to map canvas". This is not an actual sqlite
> view, but depending on what you need, it could be enough.
> > Hi Olivier,
> > added ROWID to the VIEW. Same result in QGIS.
> > I also performed the select in the DB Manager as you proposed. When
> executed, it perfectly show the results i would like to see in the
> attribute table, but what "arrives" in the attribute table after
> loading as layer is again the duplication of the the first entry for
> ROWID of the polygon.
> > So, this is my select: Anything important missing?
> > SELECT "a"."ROWID" AS "ROWID", "a"."Geometry" AS "Geometry",
> > "b"."zahl" AS "zahl", "b"."jahr" AS "jahr", "b"."art" AS "art",
> > "b"."sta" AS "sta"
> > FROM "ASK_VOEGEL" AS "a"
> > JOIN "ask_art" AS "b" USING ("id")
> > Thanx for your time
> > Bernd
> > Good luck !
> > Olivier
> > 2014-02-19 19:54 GMT+01:00 Bernd Vogelgesang
> <bernd.vogelgesang at gmx.de <mailto:bernd.vogelgesang at gmx.de>>:
> >> Am 19.02.2014 19:14, schrieb Steve G:
> >>> This does not directly answer your question about spatialite
> views, but you
> >>> might be able to use relationships directly in QGIS in the near
> future (I
> >>> think this is a 2.1 update). See:
> >>> http://blog.vitu.ch/10112013-1201/qgis-relations
> >>> -Steve
> >> Hi Steve,
> >> Actually I do not care by which means I reach my destination, but I
> had the, maybe wrong; impression that using a spatial database would
> do the trick.
> >> Anyway ...
> >> I already installed latest master cause I read about this relation
> manager thing a while ago ... but I was left quite clueless about how
> to use it.
> >> Searched the web for nearly an hour about any info but to no avail,
> so many thanks for sharing the link!!
> >> Will have a look at it ASAP, maybe thats kind of a solution.
> >> Cheers
> >> Bernd
> >>> View this message in context:
> http://osgeo-org.1560.x6.nabble.com/Spatialite-VIEW-in-QGIS-question-tp5104565p5104775.html
> >>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> >>> _______________________________________________
> >>> Qgis-user mailing list
> >>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140220/ca340bd8/attachment.html>
