[Qgis-user] Time manager QGIS plugin
Carlos Cerdán
sig.upagu at gmail.com
Thu Feb 20 13:36:55 PST 2014
Hi Nurudien
Maybe it's better if you give more details, as the error message, your
operative system and version.
When i changed field to "string" (copy to a new string filed), it was fixed
and Time Manager works fine. (Ubuntu 12.04 - QGIS 2.0)
Good luck
Carlos
2014-02-20 15:59 GMT-05:00 Nurudien Dawood <dawoodn08 at gmail.com>:
> Hi i have just been trying to get to understand and use time manger plugin
> but i have been getting the same error message with regard to the supported
> formats.
> i have been looking at the forums in relation to the plugin and came
> across the forum where i have noted that you have had the same issue..hence
> me mailing you now. i hope its not a bother.
> i have also created a test shapefile and have had the same problem. i have
> changed the "date" fields to "string" as well and changed the "date format"
> in the time manager settings also and still getting the same error. i will
> really appreciate if you can provide me with a step by step as to solve
> this problem..
> Kind regards,
> N.Dawood
> South Africa
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140220/f7d934d9/attachment.html>
