[Qgis-user] Raster Calculator - If statements
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Fri Feb 21 05:37:14 PST 2014
Hi List,
I have a three band raster. I want to do the following with:
If (Band1 > 150 AND Band2 > 150 AND Band3 > 150){
>   Band1 = 255
>   Band1 = 255
>   Band1 = 255
Basically set all band values to 255 when all band values are > than a
value of 150. All other band values should remain unchanged.
How do I do this? I've got as far as the below for the :
>  ( "CR0569TEI_00008_modified at 1" > 145 AND "CR0569TEI_00008_modified at 2" >
> 145 AND "CR0569TEI_00008_modified at 3" > 145 )
But am unsure what's next. The tutorials I've found online assume I only
want 1 or 0 as my results.
Help welcome. :-)
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140221/6c805722/attachment.html>
