[Qgis-user] OnTheFly Reprojections
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Fri Feb 21 06:41:13 PST 2014
Hi List,
Two issues,
First, I'm noticing that quite a few of the layers we have that are in
British National Grid aren't actually treated that way when I load them
into QGIS. This seems to be because they have a very slightly different
definition than the one QGIS has.
For example:
+proj=tmerc +lat_0=49 +lon_0=-2 +k=0.9996012717 +x_0=400000 +y_0=-100000
+ellps=airy +towgs84=375,-111,431,0,0,0,0 +units=m +no_defs
+ellps=airy +towgs84=446.448,-125.157,542.06,0.1502,0.247,0.8421,-20.4894
+units=m +no_defs
QGIS definition
+ellps=airy +towgs84=446.448,-125.157,542.06,0.15,0.247,0.842,-20.489
+units=m +no_defs
Three different definitions for the same thing.
This becomes a problem because On The Fly reprojection (which I've now been
forced to disable permanently) is super slow. Even a simple polygon layer
with a few dozen features on top of a WMS creates a very noticeable
(several seconds) lag.
So my question:
Is it possible to make QGIS recognise all the different definitions as one
single definition?
Using a Master build from a couple of months ago.
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140221/05e8eaf7/attachment.html>
