[Qgis-user] Problems to install Matplotlib in OSX
William Kyngesburye woklist at kyngchaos.com
Fri Feb 21 21:44:42 PST 2014
Make sure you install pyparsing as directed in the matplotlib readme.  I haven't had time to add that to the matplotlib installer yet.  Without pyparsing, matplotlib will not load, then QGIS thinks it's not installed.
On Feb 21, 2014, at 10:53 AM, José Carlos Guerrero Antúnez wrote:
> Hi,
> I downloaded from Kingchaos web the python modules matplobib 1.3.0-3, I did the installation procedure and apparently installed correctly, but when I load qgis, the program says:
> Could not find the matplotlib module.
> Make sure the matplotlib is installed
> And also, plugin as Statist is invalid because Matplotlib is not installed.
> OSX 10.6.8 (Snow Leopard)
> QGIS 2.0
> How can I fix it?
> Many thanks in advance,
> Jose Carlos Guerrero
> Dr. José Carlos Guerrero
> Laboratorio de Desarrollo Sustentable y Gestión Ambiental del Territorio (LDSGAT)
> Instituto de Ecología y Ciencias Ambientales (IECA)
> Facultad de Ciencias
> Universidad de la República
> Montevideo-URUGUAY
> Qgis-user mailing list
