[Qgis-user] OnTheFly Reprojections
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Mon Feb 24 09:30:39 PST 2014
One further thought on this - is it supposed to be so incredibly slow?
Especially given it's basically only reprojecting from/to the same
coordinate system (with a few decimal places of difference). I know that if
I open things in different projections in ArcGIS there's no noticeable lag.
Cheers,
Jonathan
On 24 February 2014 13:58, Jonathan Moules <
jonathanmoules at warwickshire.gov.uk> wrote:
> Thanks for the responses. I think that's going to have to be the longer
> term plan.
> Jonathan
> On 21 February 2014 18:46, Etienne Tourigny <etourigny.dev at gmail.com>wrote:
>> In this case you a probably better of making copies of the files with all
>> the same CRS.
>> On Fri, Feb 21, 2014 at 11:41 AM, Jonathan Moules <
>>> Hi List,
>>> Two issues,
>>> First, I'm noticing that quite a few of the layers we have that are in
>>> British National Grid aren't actually treated that way when I load them
>>> into QGIS. This seems to be because they have a very slightly different
>>> definition than the one QGIS has.
>>> For example:
>>> +proj=tmerc +lat_0=49 +lon_0=-2 +k=0.9996012717 +x_0=400000
>>> +y_0=-100000 +ellps=airy +towgs84=375,-111,431,0,0,0,0 +units=m +no_defs
>>> +towgs84=446.448,-125.157,542.06,0.1502,0.247,0.8421,-20.4894 +units=m
>>> +no_defs
>>> QGIS definition
>>> +towgs84=446.448,-125.157,542.06,0.15,0.247,0.842,-20.489 +units=m +no_defs
>>> Three different definitions for the same thing.
>>> This becomes a problem because On The Fly reprojection (which I've now
>>> been forced to disable permanently) is super slow. Even a simple polygon
>>> layer with a few dozen features on top of a WMS creates a very noticeable
>>> (several seconds) lag.
>>> So my question:
>>> Is it possible to make QGIS recognise all the different definitions as
>>> one single definition?
>>> Using a Master build from a couple of months ago.
>>> Thanks,
>>> Jonathan
>>> This transmission is intended for the named addressee(s) only and may
>>> contain sensitive or protectively marked material up to RESTRICTED and
>>> should be handled accordingly. Unless you are the named addressee (or
>>> authorised to receive it for the addressee) you may not copy or use it, or
>>> disclose it to anyone else. If you have received this transmission in error
>>> please notify the sender immediately. All email traffic sent to or from us,
>>> including without limitation all GCSX traffic, may be subject to recording
>>> and/or monitoring in accordance with relevant legislation.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140224/53dd87c7/attachment.html>
