[Qgis-user] GRASS/SAGA in OSGeo4W - not loading
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Tue Feb 25 02:36:11 PST 2014
Hi list,
I've installed QGIS 2.2 for Windows using the OSGeo4W installer. I used the
advanced install, selected QGIS-Desktop (not full) then selected the
packages I wanted including GRASS and SAGA.
The install went ahead just fine, but now when I'm in QGIS and trying to
use GRASS tools I'm getting the customary:
"Missing dependency.This algorithm cannot be run :-( "
However, in the QGIS directory there is:
C:\QGIS_2.2\apps\grass\grass-6.4.3\
which contains 2,815 files (88.8MB).
There's also a
C:\QGIS_2.2\apps\saga\
which contains 85 files (25.3MB).
So why aren't they working in QGIS? Am I doing something wrong or is this a
packaging problem?
Cheers,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140225/ad86ee6c/attachment.html>
