[Qgis-user] GRASS/SAGA in OSGeo4W - not loading
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Tue Feb 25 04:55:52 PST 2014
Hi Jürgen,
I was using the processing toolbox which is what gave me that. I'm not
sure what you mean by determining what dependency is missing. Or what
"internal tools" equates to.
I uninstalled it with the hope of putting a weekly on there but as you
know...
I'll wait for the full stand-alone install, but I can test the OSGeo4W one
if you want me to.
Cheers,
Jonathan
On 25 February 2014 12:40, Jürgen E. <jef at norbit.de> wrote:
> Hi Jonathan,
> On Tue, 25. Feb 2014 at 10:36:11 +0000, Jonathan Moules wrote:
> > The install went ahead just fine, but now when I'm in QGIS and trying to
> > use GRASS tools I'm getting the customary:
> > "Missing dependency.This algorithm cannot be run :-( "
> Is suppose this is from processing, right? Any clue what dependency is
> missing? Do internal tools work?
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
> QGIS PSC member (RM) Germany IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140225/7aeeb62e/attachment.html>
