[Qgis-user] problems with polygonize with qgis2.2
William Kyngesburye woklist at kyngchaos.com
Wed Feb 26 08:27:23 PST 2014
I added Shapely to my GEOS framework last fall.  It looks like it's having problems loading the GEOS framework.  I'll look into it this evening.
On Feb 26, 2014, at 10:18 AM, Agustin Diez-Castillo wrote:
> Not sure if the right list
> When trying to polygonize with Kyngchaos' last version I got this message.
> No sure if this problem only occurs in Mac.
> Agustin
> OSError: dlopen(/usr/local/lib/libgeos_c.dylib, 6): no suitable image found. Did find:
> /usr/local/lib/libgeos_c.dylib: no matching architecture in universal wrapper
> Uncaught error while executing algorithm
> Traceback (most recent call last):
> File "/Users/adiez/.qgis2/python/plugins/processing/core/GeoAlgorithm.py", line 202, in execute
> self.processAlgorithm(progress)
> File "/Users/adiez/.qgis2/python/plugins/processing/algs/Polygonize.py", line 48, in processAlgorithm
> from shapely.ops import polygonize
> File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 453, in _import
> mod = _builtin_import(name, globals, locals, fromlist, level)
> File "/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7/shapely/ops.py", line 7, in <module>
> from shapely.geos import lgeos
> File "/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7/shapely/geos.py", line 59, in <module>
> _lgeos = load_dll('geos_c', fallbacks=alt_paths)
> File "/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7/shapely/geos.py", line 32, in load_dll
> return CDLL(lib)
> File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ctypes/__init__.py", line 365, in __init__
> self._handle = _dlopen(self._name, mode)
> QGIS version2.2.0-ValmieraQGIS code revisionCompiled against Qt4.8.5Running against Qt4.8.5Compiled against GDAL/OGR1.10.1Running against GDAL/OGR1.10.1Compiled against GEOS3.4.2-CAPI-1.8.2Running against GEOS3.4.2-CAPI-1.8.2 r3921PostgreSQL Client Version9.3.1SpatiaLite Version4.1.1QWT Version6.0.2PROJ.4 Version480QScintilla2 Version2.8
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed robot?
[Marvin]  You think you have problems?  What are you supposed to do if you ARE a maniacally depressed robot?  No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
