[Qgis-user] Calculating acreage in 2.2
Mike Hyslop mdhyslop at mtu.edu
Thu Feb 27 13:26:32 PST 2014
Randy,
I'm getting different results from both you & Raul. Win 7 enterprise, 64
bit. OSGeo4W install of QGIS 2.2. EPSG 2274.
I took the additional steps of creating an area field (from $area) and two
acres fields: one acres calculated from $area / 43560 and one from the area
field / 43560. The two acreage fields are = but values are different than
either of you: 209 acres for the cutover field.
https://www.dropbox.com/s/oxilz8hn6a5phhx/Screenshot%202014-02-27%2016.20.55.png
https://www.dropbox.com/s/n5my6zhldh7d1rx/Screenshot%202014-02-27%2016.20.19.png
Weird...
Mike
On Thu, Feb 27, 2014 at 3:49 PM, RNanclares <raulnanclares at gmail.com> wrote:
> <http://osgeo-org.1560.x6.nabble.com/file/n5106474/acres.jpg>
> This is what i got right now using your dataset and the same procedure
> you're using to calculate acreage. Windows 7 Ultimate 64 bits. QGIS 2.2
> installed via Osgeo4W 32 bits.
> Cheers.
> http://osgeo-org.1560.x6.nabble.com/Calculating-acreage-in-2-2-tp5106417p5106474.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140227/93454f22/attachment.html>
