[Qgis-user] Calculating acreage in 2.2
Randal Hale rjhale at northrivergeographic.com
Thu Feb 27 13:37:45 PST 2014
Now there's two of us who are insane. I rebooted and the issue went away
for now......but.....it happened to you. That's somewhat of a relief. I
think.
Maybe not.
Yesh.
Randy
Randal Hale, GISP
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale
http://about.me/rjhale
On 02/27/2014 04:35 PM, Mike Hyslop wrote:
> Aaand I just tried again on a clean copy of the data. Same procedure.
> Same results as you (19.53011 acres). No idea why I got 209 acres last
> time, but the two copies of the shapefile appear identical.
> Something is rotten in Denmark (oops. Michigan). Must be time to go
> home...
> Mike
> On Thu, Feb 27, 2014 at 4:26 PM, Mike Hyslop <mdhyslop at mtu.edu
> <mailto:mdhyslop at mtu.edu>> wrote:
>     Randy,
>     I'm getting different results from both you & Raul. Win 7
>     enterprise, 64 bit. OSGeo4W install of QGIS 2.2. EPSG 2274.
>     I took the additional steps of creating an area field (from $area)
>     and two acres fields: one acres calculated from $area / 43560 and
>     one from the area field / 43560. The two acreage fields are = but
>     values are different than either of you: 209 acres for the cutover
>     field.
>     https://www.dropbox.com/s/oxilz8hn6a5phhx/Screenshot%202014-02-27%2016.20.55.png
>     https://www.dropbox.com/s/n5my6zhldh7d1rx/Screenshot%202014-02-27%2016.20.19.png
>     Weird...
>     Mike
>     On Thu, Feb 27, 2014 at 3:49 PM, RNanclares
>     <raulnanclares at gmail.com <mailto:raulnanclares at gmail.com>> wrote:
>         <http://osgeo-org.1560.x6.nabble.com/file/n5106474/acres.jpg>
>         This is what i got right now using your dataset and the same
>         procedure
>         you're using to calculate acreage. Windows 7 Ultimate 64 bits.
>         QGIS 2.2
>         installed via Osgeo4W 32 bits.
>         Cheers.
>         View this message in context:
>         http://osgeo-org.1560.x6.nabble.com/Calculating-acreage-in-2-2-tp5106417p5106474.html
>         Sent from the Quantum GIS - User mailing list archive at
>         Nabble.com.
>         _______________________________________________
>         Qgis-user mailing list
>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140227/014518e5/attachment.html>
