[Qgis-user] Bus Error (memory error)
Gpetr
gkpetrak at gmail.com
Fri Feb 28 17:06:55 PST 2014
Hello,
I was trying to process a raster image via Gdal when it's happened an
unexpected error. A Bus Error. After that, QGIS can not start. Also I
recieve the same error when I'm trying to execute any of the GDAL commands
via terminal.
I know that this error happens when a process is trying to access memory
that the CPU cannot physically address.
I checked my log files and the output of the error is the following:
T02:13:26.879355+02:00 suse-pc kernel: [ 9976.488797] ata1.00: exception
Emask 0x0 SAct 0x1 SErr 0x0 action 0x0
2014-03-01T02:13:26.879402+02:00 suse-pc kernel: [ 9976.488806] ata1.00:
irq_stat 0x40000008
2014-03-01T02:13:26.879413+02:00 suse-pc kernel: [ 9976.488813] ata1.00:
failed command: READ FPDMA QUEUED
2014-03-01T02:13:26.879419+02:00 suse-pc kernel: [ 9976.488826] ata1.00: cmd
60/08:00:50:8d:75/00:00:39:00:00/40 tag 0 ncq 4096 in
2014-03-01T02:13:26.879428+02:00 suse-pc kernel: [ 9976.488826] res
41/40:08:51:8d:75/00:00:39:00:00/00 Emask 0x409 (media error) <F>
2014-03-01T02:13:26.879434+02:00 suse-pc kernel: [ 9976.488832] ata1.00:
status: { DRDY ERR }
2014-03-01T02:13:26.879437+02:00 suse-pc kernel: [ 9976.488836] ata1.00:
error: { UNC }
2014-03-01T02:13:26.948294+02:00 suse-pc kernel: [ 9976.557999] ata1.00:
configured for UDMA/133
2014-03-01T02:13:26.948313+02:00 suse-pc kernel: [ 9976.558034] sd 0:0:0:0:
[sda] Unhandled sense code
2014-03-01T02:13:26.948315+02:00 suse-pc kernel: [ 9976.558040] sd 0:0:0:0:
[sda]
2014-03-01T02:13:26.948316+02:00 suse-pc kernel: [ 9976.558044] Result:
hostbyte=DID_OK driverbyte=DRIVER_SENSE
2014-03-01T02:13:26.948317+02:00 suse-pc kernel: [ 9976.558048] sd 0:0:0:0:
[sda]
2014-03-01T02:13:26.948318+02:00 suse-pc kernel: [ 9976.558052] Sense Key :
Medium Error [current] [descriptor]
2014-03-01T02:13:26.948320+02:00 suse-pc kernel: [ 9976.558059] Descriptor
sense data with sense descriptors (in hex):
2014-03-01T02:13:26.948321+02:00 suse-pc kernel: [ 9976.558062] 72
03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 00
2014-03-01T02:13:26.948321+02:00 suse-pc kernel: [ 9976.558081] 39
75 8d 51
2014-03-01T02:13:26.948335+02:00 suse-pc kernel: [ 9976.558090] sd 0:0:0:0:
[sda]
2014-03-01T02:13:26.948338+02:00 suse-pc kernel: [ 9976.558095] Add. Sense:
Unrecovered read error - auto reallocate failed
2014-03-01T02:13:26.948339+02:00 suse-pc kernel: [ 9976.558099] sd 0:0:0:0:
[sda] CDB:
2014-03-01T02:13:26.948340+02:00 suse-pc kernel: [ 9976.558102] Read(10): 28
00 39 75 8d 50 00 00 08 00
2014-03-01T02:13:26.948341+02:00 suse-pc kernel: [ 9976.558119] end_request:
I/O error, dev sda, sector 964005201
2014-03-01T02:13:26.948342+02:00 suse-pc kernel: [ 9976.558207] ata1: EH
complete
Any ideas ?
How can I fix it ?
Regards,
George
View this message in context: http://osgeo-org.1560.x6.nabble.com/Bus-Error-memory-error-tp5106727.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
