[Qgis-user] Plugin QGIS Error "QTextEdit.setPlainText(QString): not enough arguments"
Nathan Woodrow madmanwoo at gmail.com
Wed Jan 1 15:00:21 PST 2014
You need to use the toPlainText method.
self.ui.textRec1.toPlainText()
I will also suggest a few other tweaks to your code:
Change this:
QtCore.QObject.connect(Smpan, QtCore.SIGNAL('clicked()'),self.saveAs)
To:
Smpan.clicked.connect(self.saveAs)
Change your _save method to:
def _save(self, simpan):
   with open(simpan, 'w') as f:
         f.write( 'Input 1 :' + str(self.ui.lineInput1.text()) )
         f.write( 'Input 2 :' + str(self.ui.lineInput2.text()) )
         f.write( 'Rekomendasi :' + str(self.ui.textRec1.setPlainText()) )
On Wed, Jan 1, 2014 at 7:15 PM, Suryo Miles <suryomiles666 at gmail.com> wrote:
> I try to make save as button but i got this error message when try to save
> file in my directory
>     File
> "C:\Users\Mr.Pakde/.qgis2/python/plugins\condition\conditiondialog.py",
> line 80, in saveAs
>         self._save( _filename )
>     File
> line 68, in _save
>         f.write( 'Rekomendasi :' + str(self.ui.textRec1.setPlainText() ) )
>     TypeError: QTextEdit.setPlainText(QString): not enough arguments
> this is my code
>     Smpan = self.ui.btnSave
>         def Compare1(self):
>             input1 = self.ui.lineInput1.text()
>             input2 = self.ui.lineInput2.text()
>             compare = ''
>             if input1 == input2:
>                 compare = 'Data dapat digunakam'
>             else:
>                 compare = 'Data tidak cocok'
>             self.ui.textRec1.setPlainText(compare)
>             f = open( simpan, 'w' )
>             f.close()
>         def savefile(self):
>             if self.simpan:
>                   self._save( "%s" % self.simpan )
>             else:
>                   self.saveAs()
>         def saveAs(self):
>                 tulis = QtGui.QFileDialog(self).getSaveFileName()
>                 if tulis !="":
>                     _filename = "%s" % tulis
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140102/93ee783e/attachment.html>
