[Qgis-user] Shifting overlapping points
Randal Hale
rjhale at northrivergeographic.com
Mon Jan 6 05:49:27 PST 2014
I can confirm - I don't have it either on my install of 2.0.1 (ubuntu)
I found a "separate points by direction" tool under SAGA Shapes ->
points. Not sure if that is useful or what.
Martin - One of the things I used to do in ArcGIS (this depends on level
of licensing) was using topology. You can add a point layer and use the
topology tools to look for duplicates. I ran a point layer (emergency
addresses) and found two duplicates using the QGIS topology tools.
Randy
On 01/06/2014 08:11 AM, Martin Gibson wrote:
> Thanks Alexander. I can't see points displacement on my install.
> Under QGIS Geoalgorithms ? Vector
> geometry tools I have 18 algorithms available to me, but not that one.
> Will investigate further to see if I can find why it is missing.
> Martin
> On 6 January 2014 12:52, Alexander Bruy <alexander.bruy at gmail.com
> <mailto:alexander.bruy at gmail.com>> wrote:
> Hi Martin,
> 2014/1/6 Martin Gibson <martin at creativeinterpretation.co.uk
> <mailto:martin at creativeinterpretation.co.uk>>:
> > Hi,
> > I'm more familiar with ArcGIS than QGIS but starting to shift
> over to using
> > QGIS for most/all work. One thing I had been using QGIS for
> anyway was
> > shifting overlaid points, as I couldn't get Arc to do this. I
> was using the
> > ShiftPoints plugin, but it doesn't appear to be available for
> 2.0 - I have
> > come across a statement that it obsolete now and that I should
> use Sextante
> > instead. Can't find any info on how to achieve what I used to
> with the
> > plugin - can anyone help?
> ShiftPoints plugin now not supported as its functionality already
> available via Processing (Analysis menu). You can find this algorithm
> in the Processing toolbox under QGIS Geoalgorithms ? Vector
> geometry tools ? Point displacement.
> Alternatively you can use search box in the top of Procesing toolbox
> and type something like "disp". List of algorithms will be filtered to
> match your query.
> Hope this helps
> Alexander Bruy
> Martin Gibson
> Creative Interpretation Ltd
> w: www.creativeinterpretation.co.uk
> <http://www.creativeinterpretation.co.uk/>
> e: martin at creativeinterpretation.co.uk
> t: 01983 220044
> Creative Interpretation Ltd is a company registered in England and
> Wales number 07963113, registered office 145-157 St John Street,
> London, EC1V 4PW.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140106/f64895e0/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140106/f64895e0/attachment.png>
