[Qgis-user] Newbie - QGIS won't recongize shp files, comp turns shp files into pdfs
Anita Graser anitagraser at gmx.at
Mon Jan 6 09:15:38 PST 2014
Hi Matthew,
Please provide a step-by-step description of what you are doing to
starting from downloading the file or record a screencast
(http://www.screencast-o-matic.com/screen_recorder). It's really hard to
guess what's going wrong without details.
Best wishes,
Anita
Am 06.01.2014, 17:37 Uhr, schrieb Matt_Klick <matthew.klick at gmail.com>:
> Thank you both Frank and Alexandre,
> It is appreciated.
> I'm afraid I am using both the add vector layer, and have the complete
> set
> of files downloaded, and still no luck -- and now on several computers
> and
> having reinstalled QGIS, and having re-downloaded files, a half dozen
> times
> at least.
> I have only been using files downloaded from DIVA-GIS though, so perhaps
> I
> will try getting fields from somewhere else.
> Best, M
> On Mon, Jan 6, 2014 at 3:26 AM, Sr. Neto [via OSGeo.org] <
> ml-node+s1560n5096521h88 at n6.nabble.com> wrote:
>> Also, confirm that you have the complete set of files of shapefile.
>> You must have (at least) a .SHP, a .SHX and a .DBF with the same name.
>> Best regards,
>> Alexandre Neto
>> On Mon, Jan 6, 2014 at 6:00 AM, Frank Sokolic <[hidden
>> email]<http://user/SendEmail.jtp?type=node&node=5096521&i=0>
>> > wrote:
>>> Hi Matt,
>>> Are you using the "Add Vector Layer" command to open the shapefiles? If
>>> not, go to the "Layer" menu and select the "Add Vector Layer" command.
>>> You
>>> can then choose "Browse" to look for the shapefile you want to load.
>>> Regards, Frank.
>>> On 06/01/2014 06:57, Matt_Klick wrote:
>>>> No luck on this yet, but thank you for your suggestion. On another
>>>> computer, I still cannot upload shp files - instead changing them to
>>>> nursoft (??) files. In any event, I cannot yet open a shp file using
>>>> QGIS.
>>>> On Fri, Jan 3, 2014 at 3:19 PM, Akinyemi Bojerenu [via OSGeo.org]
>>>> <[hidden email] </user/SendEmail.jtp?type=node&node=5096495&i=0>>
>>>> wrote:
>>>>     Hi,
>>>>     Please extract the contents of the zip file first into a
>>>> destination
>>>>     folder of choice.
>>>>     When opening a shapefile, navigate to your folder to select the
>>>>     shapefile(s).
>>>>     Hope this helps..
>>>>     Yemi
>>>>     On Jan 4, 2014 9:13 AM, "Matt_Klick" <[hidden email]
>>>>     <http://user/SendEmail.jtp?type=node&node=5096323&i=0>> wrote:
>>>>         I'm very new to any GIS type platforms, so please forgive the
>>>>         ignorance on
>>>>         display here (and I did search for answers to this elsewhere).
>>>> I've
>>>>         downloaded QGIS 2.0.1. I separately downloaded Tunisia
>>>>         administrative data
>>>>         from DIVA-GIS. When I open QGIS, it does not find the .zip
>>>> file,
>>>>         nor any of
>>>>         the shp files. In my efforts to correct, I managed to convert
>>>>         shp files into
>>>>         pdfs. Even though I've re-installed QGIS, and deleted and
>>>>         re-downloaded
>>>>         Tunisia files, shp files are once again pdfs, and QGIS cannot
>>>>         "see" any shp
>>>>         files. Any advice, or thoughts on what I'm doing wrong,
>>>> greatly
>>>>         appreciated.
>>>>         -MK
>>>>         View this message in context:
>>>>         http://osgeo-org.1560.x6.nabble.com/Newbie-QGIS-won-t-
>>>> recongize-shp-files-comp-turns-shp-files-into-pdfs-tp5096322.html
>>>>         Sent from the Quantum GIS - User mailing list archive at
>>>> Nabble.com.
>>>>         _______________________________________________
>>>>         Qgis-user mailing list
>>>>         [hidden email]
>>>>         <http://user/SendEmail.jtp?type=node&node=5096323&i=1>
>>>>         http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>     [hidden email]
>>>> <http://user/SendEmail.jtp?type=node&node=5096323&i=2
>>>>     If you reply to this email, your message will be added to the
>>>>     discussion below:
>>>> tp5096322p5096323.html
>>>>     To unsubscribe from Newbie - QGIS won't recongize shp files, comp
>>>>     turns shp files into pdfs, click here.
>>>>     NAML
>>>>     <http://osgeo-org.1560.x6.nabble.com/template/
>>>> NamlServlet.jtp?macro=macro_viewer&id=instant_html%
>>>> 21nabble%3Aemail.naml&base=nabble.naml.namespaces.
>>>> BasicNamespace-nabble.view.web.template.NabbleNamespace-
>>>> nabble.view.web.template.NodeNamespace&breadcrumbs=
>>>> notify_subscribers%21nabble%3Aemail.naml-instant_emails%
>>>> 21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>>>> View this message in context: Re: Newbie - QGIS won't recongize shp
>>>> <http://osgeo-org.1560.x6.nabble.com/Newbie-QGIS-won-t-
>>>> tp5096322p5096495.html>
>>>> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>
>>>> at
>>>> Nabble.com.
>>>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5096521&i=1>
>>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5096521&i=2>
>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5096521&i=3>
>> discussion
>> below:
>> http://osgeo-org.1560.x6.nabble.com/Newbie-QGIS-won-t-recongize-shp-files-comp-turns-shp-files-into-pdfs-tp5096322p5096521.html
>>  To unsubscribe from Newbie - QGIS won't recongize shp files, comp turns
>> here<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5096322&code=bWF0dGhldy5rbGlja0BnbWFpbC5jb218NTA5NjMyMnwtMTkxMzIxODg3Nw==>
>> NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> http://osgeo-org.1560.x6.nabble.com/Newbie-QGIS-won-t-recongize-shp-files-comp-turns-shp-files-into-pdfs-tp5096322p5096580.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
anitagraser.com
