[Qgis-user] point sampling tool is there anyway to speed it up and keep it going
Anita Graser
anitagraser at gmx.at
Fri Jan 10 11:44:53 PST 2014
Hi Michael,
Try the SAGA implementation (through Processing). It's much faster, as
described in
http://anitagraser.com/2013/10/02/add-polygon-attributes-to-points-vs-join-attributes-by-location/
Best wishes,
Anita
Am 10.01.2014, 19:41 Uhr, schrieb Michael.Dodd <Michael.Dodd at open.ac.uk>:
> The point sampling plugin can be very effective but is slow when dealing
> with a large number of points and a complex area to be sampled e.g.
> hundreds of thousands of points on a relatively detailed map of world
> countries. I can cope with it being slow by just accepting it will take
> all day to run BUT it never completes because there is always something
> that happens on the pc that stops it, the last time it happened after
> about 4 hours with a couple more hours to run. If you try to use any
> other program on the pc then the tool stops and also freezes qgis. am
> currently running qgis 2.0.1 on windows7 64bit with quite a lot of ram
> although i note it never uses more than about 13% of the total ram. I
> used to run the tool with earlier versions of qgis on windowsXP and had
> the same issue with it stopping if any other program was opened on the
> pc.
> -- The Open University is incorporated by Royal Charter (RC 000391), an
> exempt charity in England & Wales and a charity registered in Scotland
> (SC 038302).
> Qgis-user mailing list
anitagraser.com
