[Qgis-user] Print Composer
Alexandre Neto senhor.neto at gmail.com
Mon Jan 13 04:38:40 PST 2014
On Mon, Jan 13, 2014 at 12:19 PM, Craig Leat <craig.leat at gmail.com> wrote:
> I have noticed I can zoom within a map frame in the Print Composer with
> the mouse wheel. Is there a way to pan within the frame? The ability to
> zoom, pan and rotate with a mouse within the map frame would be fantastic.
Part of that has been in Composer for a long time (at least 1.8). You need
to select the map item, and then click on the "Move Item Content" button.
After that, you will be able to zoom and pan of the map item with the mouse
wheel.
Best regards,
Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140113/eefadb6b/attachment.html>
