[Qgis-user] Oracle Spatial Vector Layer Buttons/Menu not visible in QGIS 2.0 on Ubuntu
chris marx chrismarx at gmail.com
Wed Jan 15 09:27:42 PST 2014
Ok. Is this requirement documented anywhere? I saw a lot of documentation
touting the ability to use Oracle Spatial, blog posts, etc., but never ran
across anything in the documentation about instructions for a custom build
in order to use this functionality. Also, I found this page:
https://raw.github.com/qgis/QGIS/master/INSTALL
Which contains instructions for doing manual builds, is this the right/best
resource for going forward? This guide doesn't include a list of the
available build options, are those available somewhere? For instance, when
building on a mac environment, several build options were passed to cmake,
see the post here:
http://gis.stackexchange.com/questions/74842/add-oracle-spatial-vector-layer-with-qgis-2-0-on-mac-osx
it also mentions OCI_LIBRARY and OCI_INCLUDE_DIR options-
Thanks,
Chris-
Date: Tue, 14 Jan 2014 23:31:29 +0100
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Oracle Spatial Vector Layer Buttons/Menu       not
Message-ID: <20140114223129.GA3026 at norbit.de>
Content-Type: text/plain; charset=iso-8859-1
Hi Chris,
On Tue, 14. Jan 2014 at 17:20:13 -0500, chris marx wrote:
> The documentation for 2.0 doesn't indicate that there are any other steps
> necessary to enable Oracle Spatial. What am I missing?
You need to rebuild QGIS with Oracle support by enabling WITH_ORACLE in
cmake.
That requires the instant client.
J?rgen
J?rgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstra?e 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
QGIS PSC member (RM)                                   IRC: jef on FreeNode
On Tue, Jan 14, 2014 at 5:20 PM, chris marx <chrismarx at gmail.com> wrote:
> I just installed QGIS 2.0 using the recommended method of manually
> updating my repository list and running sudo apt-get install qgis
> python-qgis. QGIS appears to be installed just fine, but the "add oracle
> spatial layer" button isn't in the left side button list, nor is it an
> option when trying to add a layer through the menu. The documentation for
> 2.0 doesn't indicate that there are any other steps necessary to enable
> Thank You,
> Chris-
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140115/727df3a9/attachment.html>
