[Qgis-user] Fwd: Merging polygons leaves isolated lines
Lynkos lynkosmail at gmail.com
Thu Jan 16 00:51:53 PST 2014
Thanks to everyone for the help and suggestions so far. I've uploaded all
the shapefile parts here (sorry, yesterday I was in a rush and I just
wasn't thinking):
https://www.dropbox.com/s/ru4s3bi2bt5z4c2/QGIS-merge.zip
This file is the result of several "save-as" operations, so the problem
outlined by Paolo could be a factor. But I've also tried with the original
shape file (which should be "as drawn) and it behaves in exactly the same
way.
Thanks again, Sarah.
2014/1/16 Tim Sutton <lists at linfiniti.com>
> HI Sarah
> Can you post all the parts of the shapefile that others may test (.shp
> alone is not enough we need .dbf and .shx too).
> Regards
> Tim
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140116/8ef80d4f/attachment.html>
