[Qgis-user] Problems loading/accessing QGIS Server.... what am I missing?
Peter Len peteralen at earthlink.net
Thu Jan 16 05:42:15 PST 2014
Okay, the wiki has been updated with the additional items I found for the Windows installation
-----Original Message-----
>From: Andreas Neumann <a.neumann at carto.net>
>Sent: Jan 15, 2014 3:50 PM
>To: qgis-user at lists.osgeo.org
>Subject: Re: [Qgis-user] Problems loading/accessing QGIS Server.... what am I	missing?
>Hi Peter,
>Thanks for communicating this. Most QGIS server users are on Linux. The
>Windows QGIS server users are a smaller group and only recently it seems
>that more people use QGIS server on Windows. It is therefore important
>the Windows users document the issues they have and the workarounds.
>If possible - could you please add this to the QGIS server tutorial wiki
>http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial
>Thanks a lot,
>Andreas
>Am 15.01.2014 21:42, schrieb Peter Len:
>> So, this was fixed by copying all of the .dll libraries from c:/OSGeo4W/bin to c:/OSGeo4W/apps/qgis/bin.  Not sure why none of the references I used indicated this, so I am not fully comfortable that it is truly working.  I have been able to load a QGIS Desktop project served up by QGIS Server to both ArcMap and QGIS so at least that is a start.
>>> From: Peter Len <peteralen at earthlink.net>
>>> Sent: Jan 15, 2014 1:13 PM
>>> Subject: [Qgis-user] Problems loading/accessing QGIS Server.... what am I	missing?
>>> I am using QGIS and wanted to install the QGIS Server on a Windows 7 box.  I was looking at the following pages for how to do an install on Windows 7:
>>> http://anitagraser.com/2012/04/06/qgis-server-on-windows7-step-by-step/
>>> I got the installer from http://download.osgeo.org/osgeo4w/osgeo4w-setup.exe.  When I ran the install, I did an advanced installation and selected to install the Apache Webserver and the QGIS Server.  The instructions went on to say that for Windows installs you must change FastCGI to just the CGI in the httpd_qgis.conf file. So now the httpd_qgis.conf references:
>>> LoadModule cgi_module modules/mod_cgi.so
>>> SetHandler cgi-script
>>> After another change in that conf file to change DefaultInitEnv to SetEnv (using DefaultInitEnv threw errors).  After that, I was able to start the Apache web server and was able go to the default page.  I noticed that the page indicated that there was only 1 osgeo4w application installed (phpinfo).
>>> The instructions then indicated that the following GetCapabilities call should work:
>>> http://localhost:8090/qgis/qgis_mapserv.fcgi.exe?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>>> When I ran this in the browser, it indicated that there was an error.  The error log file stated:
>>> Premature end of script headers: qgis_mapserv.fcgi.exe
>>> This made me think that there was some mismatch between changing the conf file to use "cgi" rather than "fcgi".  There is no qgis_mapserv.cgi.exe, however.  Not sure what I am missing here.  Both sets of instructions were followed and they both indicate it should be working.  Does anyone know what I may be missing?
>>> Thanks - Peter
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
