[Qgis-user] Set source for GRASS layer
Johannes Radinger johannesradinger at gmail.com
Thu Jan 16 06:23:28 PST 2014
when using the GRASS plugin it is easy to add a GRASS vector as a layer to
a QGIS Project.
However when the GRASS location gets changed (e.g. renamed), QGIS, of
course, is unable to detect the correct directory of the location and thus
the user is asked to set the directory manually. However to which file is a
GRASS layer linked? It seems that the path QGIS shows for a GRASS vector
does not exist in a GRASS data structure... Is that just a known problem
for the GRASS-QGIS plugin?
best regards,
Johannes
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140116/87b53835/attachment.html>
