[Qgis-user] Graticules in QGIS 2.0
Carlos Cerdán
sig.upagu at gmail.com
Thu Jan 23 06:22:59 PST 2014
Thank you Wesley
Another (maybe easier) way is:
1. Set your CRS in Lat-Long coordinates.
2. Insert a map in composer. This is a Lat-Long map. Put graticule. Take
note of scale.
3. In map canvas change the SRC to desired, for example UTM
4. Insert another map in composer, but just an small part that can be out
the sheet of behind the principal map. Give this small map same scale that
first.
5. Insert a scale bar, linked to second map. This scale bar has UTM units,
so you got a lat-long map, with UTM scale bar.
Regards
Carlos
2014/1/23 Wesley Roberts <jwesroberts at gmail.com>
> Hi Carlos and Lester,
> I have managed to get both a lat - lon graticule grid and a metric scale
> bar onto the same map in the composer. It is relatively straight forward.
> Set your map up in the composer with the on the fly projection set to WGS84
> Geographic. Add your graticules as per your own style and design. Lock the
> map, make sure your map is complete with all legends text etc added and
> complete. Now add another map to the composer adjacent to your map canvas,
> Make sure the size (length and breadth) is exactly the same as your canvas
> map. Now go back to QGIS and change the projection properties to your
> desired projection. Back in the composer, select the map you just added and
> click set to map canvas extent. Your second map should now be at the same
> extent as the first map except it is now projected.
> All you have to do now is add a scale bar on this map and transfer it to
> the map with the graticules.
> This is a bit of a work around and requires that you are very careful with
> how you set things up.
> Let me know if this does not make sense, it works for me.
> Regards,
> Wesley
> On Thu, Jan 23, 2014 at 3:09 PM, Carlos Cerdán <sig.upagu at gmail.com>wrote:
>> Hi Lester:
>> The way I do it is to set the SRC in Lat-Long and activate on the fly
>> trnasformation. The bad news are that you can't get a metric scale bar, not
>> yet in this version (2.0.1), so +1: I would like this option.
>> Regards
>> Carlos Cerdan
>> 2014/1/23 Lester Anderson <arctica1963 at gmail.com>
>>> Hello,
>>> I was wondering if it is possible to generate projected Lat-Long
>>> graticules for non-geographic projections (eg Lambert, Sterographic
>>> etc) within the print composer? If not, is this going to be an option in a
>>> later version?
>>> Cheers
>>> Lester
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Dr Wesley Roberts
> Cell: +27(0)83 5355 646
> skype: roberts-w
> I hear...I forget
> I see...and I remember
> I do...and I understand
> Ancient Chinese Proverb
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140123/94db8f8e/attachment.html>
