[Qgis-user] Problem with axis order of WMS
Robert Nuske rnuske at gwdg.de
Thu Jan 23 08:55:47 PST 2014
Hi Bernhard
The bug report you cite seems to describe the same problem but for QGIS web
client and QGIS Server. Looking again in the bug tracker I just found
http://hub.qgis.org/issues/9345
There is even recent work on that issue:  Alvaro Huarte offered a patch and
Jürgen Fischer added  it to master 6 days ago
I tested it using packages from ubuntugis-nightly on ubuntu quantal and the
WMS http://sg.geodatenzentrum.de/wms_dtk_bkg with EPSG:31467.
It works nicely  -> Thanks a lot for fixing!
Now awaiting eagerly Version 2.2 to point my colleagues to
If just someone would have droped a line on qgis-user list...
cheers,
  robert
Am Donnerstag, 23. Januar 2014, 15:02:27 schrieb Bernhard Ströbl:
> Hi Robert,
> Am 23.01.2014 14:44, schrieb Robert Nuske:
> > Hi Bernhardt
> > thanks a lot for checking!
> >> what client do you use? QGIS desktop?
> > just a simple QGIS 2.0.1 on the desktop
> >> are you using WMS1.1 or 1.3 in the request? AFAIK QGIS desktop 2.0.1
> >> uses 1.3
> >> EPSG:31467 has reversed axis order in WMS1.3
> > yep
> > its WMS1.3 and EPSG:3146 with weird axis ordering
> see #8 here
> http://hub.qgis.org/issues/8351
> >> Am 20.01.2014 16:44, schrieb Robert Nuske:
> >>> Does anybody else have problems with the axis order of WMS in
> >>> EPSG:31467?
> >>> Is this a bug in QGIS 2.0.1?
> >>> If yes, will it be fixed in 2.2?
> >>> Can anybody reproduce the problem with the WMS and CRS ?
> >> the map loads ok if I tick "Invert axis orientation"
> > This works for me as well, as stated below.
> > I actually assumed that QGIS would know from the combination of WMS 1.3
> > and
> > the definition of  EPSG:3146 (and some others) that the axis are reversed
> > and display the WMS without further actions.
> Would be nice but I _think_ nobody ported this information together
> hence the "hack" in QGIS as a workaround. On the other hand the
> information must be somewhere around because how should the WMS server
> know it? Hmmm, but QGIS server does not handle this properly, either.
> Bernhard
> > The "Invert axis orientation" feels rather like a hack. The problem arose
> > because colleagues didn't know they need tick another option to make a
> > standard WMS work.
> > cheers,
> >    robert
> >>> Am Mittwoch, 15. Januar 2014, 11:44:50 schrieb Robert Nuske:
> >>>> Hi QGIS-List,
> >>>> QGIS 2.0.1 seems to have problems with the axis orientation of WMS'
> >>>> with
> >>>> CRS EPSG:31467.
> >>>> I had problems with WMS' from the German BKG. Reproducible with the
> >>>> freely
> >>>> accessible WMS: http://sg.geodatenzentrum.de/wms_dtk_bkg?
> >>>> EPSG:31467 is one of the CRS with uncommon axis order: northing,
> >>>> easting.
> >>>> The WMS is only shown in QGIS 2.0.1 if the option "Invert axis
> >>>> orientation"
> >>>> is selected in the "Create a new WMS connection" menu.
> >>>> Which kind of works but is a hassle and has to be rediscovered by every
> >>>> user
> >>>> I found only one related bug report: http://hub.qgis.org/issues/4443
> >>>> It is claimed there that the bug was fixed a year ago.
> >>>> So my question is, is this a speciality of the WMS I am using or is it
> >>>> still a general problem?
