[Qgis-user] Unchecked layers and groups in qgis-web-client
Andreas Neumann
a.neumann at carto.net
Mon Jan 27 11:46:39 PST 2014
Hi Gunnar,
As Bernhard said - you are using an old and partially broken version of
the QGIS web client. Please upgrade and both your layer tree issue and
the title bar issue will be solved.
Just be sure you do not overwrite your settings in the
"GlobalOptions.js" and the "GISProjectListings.js" file. I recommend to
do a file comparison between your custom version and the new version as
you will have to merge the new additions into these two files or you may
get troubles.
Good luck,
Andreas
Am 27.01.2014 17:50, schrieb Gunnar Oehmichen:
> Hi Bernhard thanks for the remarks and the hint on GetProjectSettings and
> generally for the effort of developing this in most aspects easily installed
> web-client.
> Since I am not familiar with javascript Im quite fine with this solution.
> One thing, in GlobalOptions.js:
> //first part of titlebar text
> var titleBarText = "GIS-Browser - "; // will be appended with project title
> Therefore I would expect the header of the webclient to look like:
> Logo GIS-Browser - Forest, Waste and vineyard residues - Administrative
> regions
> since the project file starts like this:
> <!DOCTYPE qgis PUBLIC 'http://mrcc.com/qgis.dtd' 'SYSTEM'>
> <qgis projectname="Forest, Waste and vineyard residues - Administrative
> regions" version="2.0.1-Dufour">
> <title>Forest, Waste and vineyard residues - Administrative
> regions</title>
> So why is "WMS" inserted instead of my project title?
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Unchecked-layers-and-groups-in-qgis-web-client-tp5100015p5100270.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
