[Qgis-user] Guides and grid in Print Composer
Ross McDonald ross at mixedbredie.net
Mon Jan 27 23:20:39 PST 2014
Thanks for logging the issue, Ramon
In the end I used the size and position options to get everything aligned.
Ross
On 28 Jan 2014, at 00:12, Ramon AndiƱach wrote:
> On 28 Jan 2014, at 0:13, "McDonaldR" <McDonaldR at angus.gov.uk> wrote:
>> Hi list,
>> I am using the new Print Composer features in the frozen development release 2.1 105ecfa.  I am setting up a map template and using the new guides and rulers to lay out the page.
>> <image001.png>
>> I want the two boxes (map on the left and sidebar on right) to snap to the guides. Moving the map frame first it seems that the centre of the box of the mouse handles snap to the guide and not the edge of the map frame.
>> <image002.png>
>> <image003.png>
>> I am running QGIS on Windows 7 32bit and I must say that running it on Linux Mint 16 (Ubuntu 13.10) it works as expected and features are snapped exactly edge to edge and corner to corner.  Anyone else experienced this issue?
>> Cheers
>> Ross
> I can confirm that (win7 64bit) and have created an issue:
> hub.qgis.org /issues/9443
> Not sure on a workaround, you might be able to finesse a grid into the right place...
> -ramon.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140128/21f4f95e/attachment.html>
