[Qgis-user] Mapinfo and qgis file's datum problem
M. LATTES ml at interatlas.fr
Tue Jan 28 05:35:34 PST 2014
Don't forget that in polar coordinates (so WGS84) the X scale and Y scale
are not the same and not constant in projected meter.
I will look into two directions :
1°) Check that the "core" units and projections of MapInfo are the same as
your project projection :
I'm not familiar with your MapInfo version, but I know that in previous
version (8.5 and above), the projection and units of the current map window
are distinct of the "core" (or default) mapinfo projection and unit.
By "core" I mean that when you use some tools, extensions, mapbasic,...
mapinfo may use the projection and units of the main settings, not the one
of the current map window.
2°) Check that your Qgis and MapInfo buffer are polygons, not Ellipse (or
arc) objects that store the radiuses and center and compute the shape.
Mathieu LATTES
-----Message d'origine-----
De : qgis-user-bounces at lists.osgeo.org
[mailto:qgis-user-bounces at lists.osgeo.org] De la part de nagellette
Envoyé : mardi 28 janvier 2014 14:01
À : qgis-user at lists.osgeo.org
Objet : Re: [Qgis-user] Mapinfo and qgis file's datum problem
Is there any one to help?
View this message in context:
http://osgeo-org.1560.x6.nabble.com/Mapinfo-and-qgis-file-s-datum-problem-tp
5091891p5100434.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
Ce courrier électronique ne contient aucun virus ou logiciel malveillant parce que la protection avast! Antivirus est active.
http://www.avast.com
