[Qgis-user] joinning tables
Siki Zoltan siki at agt.bme.hu
Tue Jan 28 23:34:54 PST 2014
Dear James,
thanks for your answer.
My data are available here:
http://www.agt.bme.hu/gis/qgis/ods.zip
You can find in the zip  a shapefile (megye_utf-8), and some spreadsheet
files (ksh.ods, ksh.xlsx, ksh.csv) having the same data.
All use utf-8 code page.
Open megye_utf-8 and ksh.ods and make a join using "megye" and "Nev"
columns. I get NULL data in all joined column.
If ods or xlsx is not supported on your platform, you can use ksh.csv.
If you join the two tables using "kod" (integer value) column, the result
is OK.
I tested it in 2.1, 1,7 and 1.8 on Linux and in 2.1 on Windows.
Best Regards,
Zoltan
On Wed, 29 Jan 2014, James Wood wrote:
> Zoltan,I don't know if someone has responded to you about this; I didn't see any list posts. I am not seeing the same issue with textual joins in my QGIS 2.0.1 install. If you want to provide me with your shapefile and your join files, I'll be happy to test here.
> Best Regards,James
>> Date: Sat, 25 Jan 2014 20:43:59 +0100
>> From: siki at agt.bme.hu
>> To: qgis-user at lists.osgeo.org
>> CC: qgis-developer at lists.osgeo.org
>> Subject: [Qgis-user] joinning tables
>> Dear List,
>> I got into trouble joining tables in QGIS.
>> When I try to join shape to a csv, ods or xlsx file using columns with
>> textual data, it doesn't work. I get only NULL values in the joint
>> columns.
>> Using integer values the join works.
>> Is it a feature or an error?
>> Regards,
>> Zoltan
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
