[Qgis-user] joinning tables
James Wood jwood911 at gmail.com
Wed Jan 29 17:24:29 PST 2014
 Zoltan,Just doing some testing with your shapefile: I was going to test this join error after importing the original megye_utf-8.shp into a SpatiaLite database, however it won't recognize it when I specify UTF-8 on import via the spatialite-gui (load shp error:Invalid character sequence). This leads me to think there might be something going on with your shapefile. So, I created a new shapefile (specifying UTF-8 encoding) and loaded the polygons from the original, minus the 'Nev' field values. Then I manually added some of those values back in (Budapest, Vas, Zala, Fejér and Békés). I had previously created a new ods file with some of the spreadsheet values for the same areas (also UTF-8 encoded). With the new shapefile and the new ods loaded into QGIS Desktop, all of the records join correctly via the text join whether they have accents or not. I would recommend trying to recreate your shapefile to be sure of the UTF-8 encoding and go from there. Best Regards,James
> Date: Wed, 29 Jan 2014 22:27:13 +0100
> From: siki at agt.bme.hu
> To: jwood911 at gmail.com
> CC: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] joinning tables
> Dear James,
> thanks for your answer.
> I used Save as in QGIS to convert the shape attributes from ISO-8859-2 to
> UTF-8. If the code page of the joinded tables are different, QGIS uses the
> code page of the joint table.
> Regards,
> Zoltan
> On Wed, 29 Jan 2014, James Wood wrote:
> > Zoltan and Szilard,
> > I have tested Zoltan's data with my installation of QGIS 2.0.1 on Windows 7
> > x64. I am seeing the same problem with the original data. When I re-create
> > some of the rows in a new Libre Office spreadsheet (Budapest, Vas, Zala),
> > the join works fine. When I add Békés that row fails in the join. Maybe
> > there is an issue with the UTF-8 encoding in the shapefile?
> > Best Regards,
> > James
> > On Wed, Jan 29, 2014 at 3:19 AM, Siki Zoltan <siki at agt.bme.hu> wrote:
> >> Dear Szilard,
> >> to tell you the truth all spreadsheet files were created by libre office,
> >> I was able to open all as a vector layer (without grapics).
> >> Which version and platform do you use?
> >> I didn't test it on 64 bit Windows.
> >> Regards,
> >> Zoltan
> >> On Wed, 29 Jan 2014, Szabo Szilard wrote:
> >>  Dear Zoltan,
> >>> To tell the truth I do not know what is happening.
> >>> I am not able to read this file normally. CSV's first does not become a
> >>> field-header (I checked with my previous csv-s and they work); I created a
> >>> new CSV using MS Office 2010 but the results was the same.
> >>> XLSX also was wrong, values became NULL in the table (but had the right
> >>> header ...).
> >>> I will continue in the afternoon ...
> >>> Best wishes,
> >>> Szilard
> >>> 2014-01-29 Siki Zoltan <siki at agt.bme.hu>
> >>>  Dear Szilard,
> >>>> thank your case study.
> >>>> DBF file limits column names to 10 char
> acters.
> >>>> First I thought special Hungarian characters cause the problem, but using
> >>>> only English ABC I got the same result.
> >>>> Did you try to join my tables?
> >>>> Did you get false result using textual columns?
> >>>> Best Regards,
> >>>> Zoltan
> >>>>  Dear Zoltan,
> >>>>> I had this kind of problem when I "hurt" the normal rules of field names
> >>>>> (i.e. using extra long field names bringing them directly from
> >>>>> downloaded
> >>>>> TEIR tables); afterI correction them (shortening but I am not sure the
> >>>>> threshold), everything was fine. But You have correct and short field
> >>>>> names
> >>>>> ... my response is just a case study.
> >>>>> Best regards,
> >>>>> Szilard
> >>>>>  Dear James,
> >>>>>> My data are available here:
> >>>>>> http://www.agt.bme.hu/gis/qgis/ods.zip
> >>>>>> You can find in the zip  a shapefile (megye_utf-8), and some
> >>>>>> spreadsheet
> >>>>>> files (ksh.ods, ksh.xlsx, ksh.csv) having the same data. All use utf-8
> >>>>>> code
> >>>>>> page.
> >>>>>> Open megye_utf-8 and ksh.ods and make a join using "megye" and "Nev"
> >>>>>> columns. I get NULL data in all joined column.
> >>>>>> If ods or xlsx is not supported on your platfo
> rm, you can use ksh.csv.
> >>>>>> If you join the two tables using "kod" (integer value) column, the
> >>>>>> result
> >>>>>> is OK.
> >>>>>> I tested it in 2.1, 1,7 and 1.8 on Linux and in 2.1 on Windows.
> >>>>>> Best Regards,
> >>>>>> Zoltan
> >>>>>>  Zoltan,I don't know if someone has responded to you about this; I
> >>>>>> didn't
> >>>>>>  see any list posts. I am not seeing the same issue with textual joins
> >>>>>>> in my
> >>>>>>> QGIS 2.0.1 install. If you want to provide me with your shapefile and
> >>>>>>> your
> >>>>>>> join files, I'll be happy to test here.
> >>>>>>> Best Regards,James
> >>>>>>>  Date: Sat, 25 Jan 2014 20:43:59 +0100
> >>>>>>>> To: qgis-user at lists.osgeo.org
> >>>>>>>> CC: qgis-developer at lists.osgeo.org
> >>>>>>>> Subject: [Qgis-user] joinning tables
> >>>>>>>> Dear List,
> >>>>>>>> I got into trouble joining tables in QGIS.
> >>>>>>>> When I try to join shape to a csv, ods or xlsx file using columns
> >>>>>>>> with
> >>>>>>>> textual data, it doesn't work. I get only NULL values in the joint
> >>>>>>>> columns.
> >>>>>>>> Using integer values the join works.
> >>>>>>>> Is it a feature or an error?
> >>>>>>>> Regards,
> >>>>>>>> Zoltan
> >>>>>>>> _______________________________________________
> > Qgis-user mailing list
> >>>>>>>> Qgis-user at lists.osgeo.org
> >>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> >>>>> Dr. Szilard SZABO
> >>>>> associate professor, head of department
> >>>>> Department of Physical Geography and Geoinformation Systems
> >>>>> University of Debrecen
> >>>>> http://www.mendeley.com/profiles/szilard-szabo/
> >>>>> Publications <https://vm.mtmt.hu/search/slist.php?lang=0&AuthorID=
> >>>>> 10000172>
> >>> Dr. Szilard SZABO
> >>> 10000172>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140130/11cf3437/attachment.html>
