[Qgis-user] QGIS Mapserver with Lighttpd
Ivan Mincik
ivan.mincik at gmail.com
Thu Jul 10 02:44:33 PDT 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 07/09/2014 08:37 PM, Larry Shaffer wrote:
> Hi Ivan,
> On Wed, Jul 9, 2014 at 6:46 AM, Ivan Minčík <ivan.mincik at gmail.com> wrote:
>> Hi all, is anybody using QGIS Mapserver with Lighttpd and FastCGI ? Is
>> QGIS projects update working without Lighttpd restart ?
>> Can somebody share Lighttpd config ?
> The labeling unit tests use qgis_local_server.py [0] to auto-launch and
> control a lighttpd/spawn-fcgi configuration [1] of independent processes.
> You can see the parameters passed to the start/stop/restart shell scripts
> here [2], for Debian and Mac (sorry no Windows yet, but please contribute
> one if you can).
> Note: this is a local-only setup, merely to save PNGs of server output to
> compare against control images and other rasterized output. It is by no
> means secure, or robust; but, it is a working setup from which you can
> start. Also, it uses very minimal resources.
> Good luck, and please contribute any working configs you come up with for
> a production setup, so they can be included in the Server Tutorial.
> I am planning on adding a lighttpd/spawn-fgi and Nginx/(spawn-fgi or
> uWSGI) setup configs section for the Server Tutorial, just not sure when.
> [0]
> https://github.com/qgis/QGIS/blob/master/tests/src/python/qgis_local_server.py
[1]
> https://github.com/qgis/QGIS/tree/master/tests/testdata/qgis_local_server
> [2]
> https://github.com/qgis/QGIS/blob/master/tests/src/python/qgis_local_server.py#L164-L236
> Regards,
> Larry Shaffer Dakota Cartography Black Hills, South Dakota
Thanks a lot Larry.
Ivan Minčík
ivan.mincik at gmail.com GPG: 0x79529A1E http://imincik.github.io/0x79529A1E.key
ivan.mincik at gista.sk GPG: 0xD714B02C http://imincik.github.io/0xD714B02C.key
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQEcBAEBAgAGBQJTvmCBAAoJEPfdLsR5UpoeaA8H/iSpK2YTSAi0DV5+K9XZNP52
AL4wiFUe55UXS/838OIXOi8VzsMEQBgPHI/+njTNqb/dNuRTD8L8I89XZnFONkl3
CAtmw6y7JM1oDfOnCrBfR1FHOtooffosEAzpqI5pfrlGDU9f9czv0R6nTR7ZEi7m
0x6WTbt7Gn8iahlIQm5rIhApqaqnI6Ij37EDUkWahoEtRsWCaoEYWXzbBdeiqM2J
1ljoe+05SjRrzmoEYBvKWiSypMOxheSeYJXuVbl/UVhe/95aTmZWzZG7Xac2lcCq
3afLCM9PxPVo92nQ/qJCPo9AmGoyFuRhD90TbXuH2qKGQqS8tIKeOmpuTifGdAY=
=OJ7t
-----END PGP SIGNATURE-----
