[Qgis-user] How to filter features by date
Anita Graser
anitagraser at gmx.at
Tue Jul 15 23:58:05 PDT 2014
OGR changed the syntax. I had the same issue in the TimeManager
plugin. See the discussion on http://trac.osgeo.org/gdal/ticket/5507
Best wishes,
Anita
On Wed, Jul 16, 2014 at 8:22 AM, Zoltan Szecsei <zoltans at geograph.co.za> wrote:
> Hi,
> On 2014/07/16 06:00, Mark Coletti wrote:
> I have an attribute type of "QDate" and I wish to filter out features that
> are older than a given date. However I cannot seem to come up with the
> right magical incantation in the qgis filter to do so.
> I do the following:
> 1. right-click on the vector layer and select "Filter ..."; the Query
> Builder dialog appears
> 2. In the expression field I write:
> "SampleTime" <= "2011/07/01"
> Try double quotes for "Fields" and single quotes for 'values'
> Regards,
> Zoltan
> For which I get the following error:
> An error occurred when executing the query.
> The data provider said:
> OGR[3] error 1: Type mismatch or improper type of arguments to <= operator.
> So how do I get this to work?
> Thanks!
> Mark
> mcoletti at gmail.com
> Qgis-user mailing list
> Zoltan Szecsei PrGISc [PGP0031]
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Services
> P.O. Box 7, Muizenberg 7950, South Africa.
> Mobile: +27-83-6004028
> Fax: +27-86-6115323 www.geograph.co.za
