[Qgis-user] Problems with RGB channels for jpg
Otto Dassau
dassau at gbd-consult.de
Wed Jul 16 23:58:22 PDT 2014
Dear Nicole,
it might be a "problem" of your hardware and difficult to solve on the ml,
if it only happens on your pc with the same layer. As a workaround for that
file, you could create a .qml style file for the jpg file, after you changed
the channel order to r,g,b as necessary. This lets QGIS load the file with
the channel order you defined.
Kind Regards
Otto
Am Fri, 11 Jul 2014 09:28:07 +0200
schrieb Nicole Stoffels <stoffels at f2e.de>:
> Dear all,
> I seem to have a problem loading a jpg or other picture formats in QGIS.
> If I drag and drop a jpg to QGIS, the green channel is not defined in
> the properties which makes the jpg pink. I can add it manually in the
> properties, but first the picture is pink by default. If my colleagues
> load the same picture, they don't have this problem. There the red,
> green and blue channel are found by QGIS.
> I am using a QGIS 2.4 (same as my colleagues) but the problem already
> occurred in my old QGIS version. Furthermore I am using an ubuntu 12.04
> on 64 bit machine.
> Did anybody ever hear of this problem or also had it himself?
> Thanks for your help!
> Best wishes
> Nicole Stoffels
> Qgis-user mailing list
Geoinformatikbüro Dassau - http://www.gbd-consult.de
FOSSGIS consulting , training , support and analysis
Ackerstrasse 144c , D - 40233 Düsseldorf , Germany
Tel: +49-(0)211-47468178 , Mobil: +49-(0)171-4687540
Community Advisor - QGIS Project Steering Committee
