[Qgis-user] Decimal numbers in Qgis
Lene Fischer
lfi at ign.ku.dk
Wed Jul 23 01:02:16 PDT 2014
You choose decimal number - but do you remember to set precision (decimal)?
Regards
Lene
-----Oprindelig meddelelse-----
Fra: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af Hakala Oiva (MTT)
Sendt: 23. juli 2014 09:38
Til: Werner Macho
Cc: qgis-user at lists.osgeo.org
Emne: Re: [Qgis-user] Decimal numbers in Qgis
More info
I open Qgis, create a new shapefile layer, add some attribute with type decimal number, then I allow editing, add a feature and Qgis asks attributes, but when I try to type a decimal separator (. or , ) Qgis does not accept it at all.
I tried that several times with original locale and also internally changed en-locale. Always the same behaviour.
Oiva
________________________________________
Lähettäjä: Werner Macho [werner.macho at gmail.com]
Lähetetty: 23. heinäkuuta 2014 8:42
Vastaanottaja: Hakala Oiva (MTT)
Kopio: qgis-user at lists.osgeo.org
Aihe: Re: [Qgis-user] Decimal numbers in Qgis
Hi!
Is it possible to provide the shapefile somewhere to take a closer look at it?
regards
Werner
On Wed, Jul 23, 2014 at 7:37 AM, Hakala Oiva (MTT) <oiva.hakala at mtt.fi> wrote:
> Hi
> I am new here, but in trouble with Qgis.
> I have a BAD problem with decimal numbers in shapefile attribute tables.
> My set:
> Ubuntu Linux 12.04
> Qgis 2.2
> Locale FI
> Example:
> The original number in attribute table is: 342,52189242800
> Using binary editor I can see, that the internal format in dbf-file is:
> 3.42521892428e+002
> And when I load the shapefile to Qgis, the result is: 3.00000000000
> That is unaccepteble! In every attribute table all the digits beyond
> decimal separator are gone and the result is only integers.
> So, what to do? This kind of prevents me from doing any serious work
> with Qgis. I have never used any program before, that cannot handle
> decimals! I have tried to use different locale internally in Qgis
> (english), but no help.
> Oiva
> Qgis-user mailing list
