[Qgis-user] Marker Symbol
Andreas Neumann
a.neumann at carto.net
Thu Jul 24 04:13:08 PDT 2014
Yes - you can use any attribute of a feature as the source of a label.
If your data is in a point layer that is possible.
There are also background shapes (rectangles, circles, SVG, etc.) available.
So yes - it is totally feasible to do what you want. Just have a look at
the many labeling options.
You can't label individual vertices of a line feature, though. In this
case you would have to create a derive point feature layer first.
Hope this helps,
Andreas
Am 24.07.2014 09:50, schrieb les at true3d.com.au:
> I am seeking assistance in creating a composite marker symbol for a
> point layer. I would like to create a rectangular point marker that
> contained the actual number of the point. The marker will be different
> for each point. Is this possible in QGIS 2.4 Chugiak.
> I would appreciate any assistance.
> Regards,
> Les Searle
> Qgis-user mailing list
