[Qgis-user] Qgis server returns map from another project, that is defined in URL
Jan Michálek
godzilalalala at gmail.com
Thu Jul 24 12:24:11 PDT 2014
One more interesting thing, I'm able to select layers from wms, if they
have the same names. Maybe is solution for me select unique name for all
layers in my projects.
2014-07-24 20:34 GMT+02:00 Jan Michálek <godzilalalala at gmail.com>:
> Thanks
> No, this problem is not in browser, becouse we had try it on more
> computers in the same time. And I opened it in qgis (wms)...
> Je;
> 2014-07-24 20:27 GMT+02:00 Alex Mandel <tech_dev at wildintellect.com>:
> On 07/24/2014 09:56 AM, Jan Michálek wrote:
>> > Have a nice day
>> > I have problem with qgis server (2.2). I have a few projects in my
>> folders
>> > and qgis doesn't use project specify in my url.
>> > For example i had folder called
>> > projects
>> > with two files. red.qgs a green.qgs with the same layer (from postgis),
>> but
>> > with differenet symbology (fill color).
>> > i use for first time url like this
>> http://nejakejservr.cz/cgi-bin/qgis_mapserv.fcgi?MAP=/mnt/data/projects/red.qgs&REQUEST=GetMap&BBOX=-615170.147011,-1003827.798116,-614613.882202,-1003027.916641&CRS=EPSG:5514&WIDTH=400&HEIGHT=300&LAYERS=test&STYLES=,,&FORMAT=image/png&DPI=96
>> > And I obtain red filled polygons (as is specified in red.qgs project).
>> > If i use this.
>> http://nejakejservr.cz/cgi-bin/qgis_mapserv.fcgi?MAP=/mnt/data/projects/green.qgs&REQUEST=GetMap&BBOX=-615170.147011,-1003827.798116,-614613.882202,-1003027.916641&CRS=EPSG:5514&WIDTH=400&HEIGHT=300&LAYERS=test&STYLES=,,&FORMAT=image/png&DPI=96
>> > I should obtain layer from green.qgs project, but i obtain red filled
>> > polygons from project i had use before.
>> > I had use qgis (2.4) on my desktop for this wms, but with the same
>> problem.
>> > I get lazers from first used project.
>> > Why?
>> > How I can change this?
>> > Thanks Je;
>> Could it be your browser is caching the page since the url is the same
>> and only the parameters are changing? Try clearing your cache and
>> starting with the green url.
>> Thanks,
>> Alex
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140724/d789c1ce/attachment.html>
