[Qgis-user] Opening Raster from ESRI .GDB
Michael Treglia
mtreglia at gmail.com
Thu Jul 24 12:56:00 PDT 2014
Hi Even,
Thanks a lot for the quick response - I really appreciate your work in
dealing with the GDB files!
That sounds great! Let me know if you need more data examples and such.
Just a quick question - .gdb is not typically forward and backward
compatible across Arc versions, right? [I've definitely had .gdb files that
don't work in QGIS, while some do, so I have assumed that it was due to
versioning issues - is that right? Or should I be doing some
trouble-shooting?]
Thanks again, and best regards,
Mike
On Thu, Jul 24, 2014 at 3:27 PM, Even Rouault <even.rouault at mines-paris.org>
wrote:
> Le jeudi 24 juillet 2014 18:19:14, Michael Treglia a écrit :
> > Hi All,
> > I've Googled around, and it seems like this isn't currently possible, but
> > wanted to check with folks on this list for any solution...
> > A lot of data being produced by agencies is now available only as ESRI
> .gdb
> > files. A dataset I'm particularly interested in working with is a gridded
> > soil dataset (
> http://www.nrcs.usda.gov/wps/portal/nrcs/detail/soils/ref/?cid=nrcs142p2_05
> > 3628 )
> > These particular data are in raster format, stored as Arc 10.1 .gdb,
> > available from here: http://datagateway.nrcs.usda.gov/GDGOrder.aspx
> Mike,
> When I reverse-engineered the vector part of FileGDB format that lead to
> the
> OGR OpenFileGDB driver of GDAL 1.11, I came through a few raster GDB
> samples.
> Dealing with them was not in the scope of the work that was funded, but
> from
> what I've seen, I've good hope that decoding them would be reachable. Would
> need some extra investigation of course to confirm and complementary
> funding...
> Best regards,
> Even
> > Any suggestions are appreciated.
> > Thanks!
> > Mike
> Geospatial professional services
> http://even.rouault.free.fr/services.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140724/139e41e6/attachment.html>
