[Qgis-user] Composite marker Symbol
Andreas Neumann
a.neumann at carto.net
Fri Jul 25 00:27:44 PDT 2014
Hi Les,
data-driven symbology and labeling is certainly possible. Look out for
these small icons next to each property widget where you can either
choose an attribute column or a QgsExpression (calculation). This works
for virtually any property. If something is missing, it could certainly
be added.
Regarding the legend, things are more complicated. If you use a lot of
data-driven symbology and labeling, generation of legends (both in the
layer tree and in print composer) will not work properly. In print
composer you can use a static legend as a workaround. You can draw the
legend yourself in a graphics package like Illustrator/Inkscape and
import the legend as SVG.
It is an open, not so easy to solve issue how to properly generate
dynamic legends based on data-defined symbology and labeling - to still
work fast enough - and do not destroy a print layout.
Ideas/comments/funding welcome ;-)
Andreas
Am 24.07.2014 21:06, schrieb les at true3d.com.au:
> Andreas,
> Thank you for your advice regarding dynamic labelling. I am able to
> label my map similar to your example. In the legend I would like to
> show a marker symbol with a short description. I would like the marker
> to be data driven rather than create each marker individually. Can this
> be done in QGIS 2.4 Chugiak?
> Once again, thank you for your assistance.
> Regards,
> Les Searle
> Qgis-user mailing list
