[Qgis-user] Vortex coordinates
G. Allegri
giohappy at gmail.com
Sun Jul 27 08:30:09 PDT 2014
You can extract the vertexes of your polygon as a new layer. You can do it
with a tool that you can find under the Vector menu and/or Processing QGIS
algorithms, I don't remember exactly and I don't have a PC right now.
Then you can use the Field Calculator to create two new columns on your
point layer using the $x and $y expressions. I. e. open the attribute
table, toggle on editing, and open the Field Calculator. Set the new field
as "Double" (decimal) and choose a meaningful precision. Write in the
expression $x. This will populate thw new column with the X coordinates of
your points. Do the same for Y.
Then you can save the point layer as CSV, that you can open in a
spreadsheet editor like Excel.
giovanni
Il 27/lug/2014 17:18 "daniel pinto" <daniel.ar.pinto at gmail.com> ha scritto:
> Dear all
> I've got a limited protection zone around a city witch is a poligonon and
> i need to know pease if its possible to make a excel sheet with the
> vortexes coordinates.... i kwon that with the fild calculator i can know
> the nr of vortices is it possible to add theur coordinates automaticly??!
> Thanks in advanced!!!
> All the best
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140727/dd39a3ac/attachment.html>
