[Qgis-user] In QGIS 2.4 disappeared the setting of mode-identify
Michael Treglia
mtreglia at gmail.com
Mon Jul 28 13:58:53 PDT 2014
I just created a group of line- based vector layers and the Identify tool
is available. What do you mean by the "Legend"? (If you mean the "Identify
Results" pane, I just noticed that the "View" menu gets grayed out.
mike
On Mon, Jul 28, 2014 at 4:42 PM, G. Allegri <giohappy at gmail.com> wrote:
> Have you tried to create a group and select it in the Legend? Identify is
> not avaiable. I'm on a master build right now.
> 2014-07-28 22:39 GMT+02:00 Michael Treglia <mtreglia at gmail.com>:
> Hmm, weird - what's your setup? I'm on QGIS 2.4, and its working fine for
>> me on both 64 and 32 bit installs, on Win7 x64
>> On Mon, Jul 28, 2014 at 4:33 PM, G. Allegri <giohappy at gmail.com> wrote:
>>> Identify is greyed until a layer isn't selected. It means the "mode"
>>> cannot be set inside the pane (because identify isn't available) if a group
>>> is selected instead of a layer in the TOC. If you confirm this I consider
>>> it a bug.
>>> giovanni
>>> 2014-07-28 22:30 GMT+02:00 Michael Treglia <mtreglia at gmail.com>:
>>> In 2.4 for me, it is in the bottom of the window/pane that pops up when
>>>> I select the identify tool, as "mode"
>>>> Hope that helps,
>>>> mike
>>>> On Mon, Jul 28, 2014 at 4:15 PM, Andrea Peri <aperi2007 at gmail.com>
>>>> wrote:
>>>>> Hi,
>>>>> In the qgis 2.2 in option->map tools there was the option to set
>>>>> the mode of identify (current/topdown stop first/layer selection)
>>>>> In the qgis 2.4 this setting in not available in the same place.
>>>>> Is it move to another position ?
>>>>> Thx.
>>>>> Andrea Peri
>>>>> qwerty àèìòù
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Giovanni Allegri
>>> http://about.me/giovanniallegri
>>> Twitter: https://twitter.com/_giohappy_
>>> blog: http://blog.spaziogis.it
>>> GEO+ geomatica in Italia http://bit.ly/GEOplus
> Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140728/897b0763/attachment.html>
