[Qgis-user] problem with printing visualizer
mara mulero muleromara at hotmail.com
Thu Jun 5 02:33:04 PDT 2014
Dear all,
So, finally I
was able to fix the problema following the advice (found in the forum) I copy below, BUT it only
worked after deleting all the print designs I had before AND following the steps with
ONLY ONE new print design open.
This is how
you can re-show those Composer GUI elements using PyQGIS (should work on all
platforms).
Launch
     QGIS and open the affected project file.Open
     up the affected print composer. Open only one composer after a clean
     restart of QGIS.Execute
     the following Python code in QGIS's Python Console:
from PyQt4.QtGui
import * cw = qgis.utils.iface.activeComposers()[0].composerWindow()  cw.findChild(QToolBar, 'toolBar').show()
cw.findChild(QDockWidget, 'CompositionDock').show() cw.findChild(QDockWidget,
'ItemDock').show() cw.findChild(QDockWidget, 'CommandDock').show()
Thanks to all the people who helped me.
Best regards,
Mara
To: muleromara at hotmail.com; qgis-user at lists.osgeo.org
Subject: RE: [Qgis-user] problem with printing visualizer
Date: Thu, 5 Jun 2014 06:05:53 +0000
Hello,
I’m not sure if I understood your problem right. But once I „lost“ some toolbars too. I had to delete the value of
HKEY_CURRENT_USER\Software\QuantumGIS\QGIS\UI\state in my windows registry.
Hope this helps.
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org]
On Behalf Of mara mulero
Sent: Wednesday, June 04, 2014 5:32 PM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] problem with printing visualizer
>Dear all,
>Accidentally, I made the toolbar of the printer visualizer disappear.
>Anyone knows how to recover it?
>I am using 1.8.0 Lisboa for mac
>Thank you very much
Der E-Mail-Dienst des Oberbergischen Kreises dient ausschließlich der dienstlichen Kommunikation.
Senden Sie deshalb keine E-Mails privaten Inhalts an E-Mail-Adressen des Oberbergischen Kreises.
Es wird darauf hingewiesen, dass neben der Person, an die Ihre E-Mail gerichtet ist, auch deren Vertretung im Amt einen unmittelbaren Zugriff auf Ihre Nachricht hat. Für Berufsgeheimnisträger und besondere Funktionsträger gelten abweichende Regelungen.
Es wird außerdem darauf hingewiesen, dass die Kommunikation per E-Mail ohne Authentifizierung und Verschlüsselung unsicher ist, da für unberechtigte Dritte grundsätzlich die Möglichkeit der Kenntnisnahme und Manipulation besteht.
Es wird deshalb keine Verantwortung für den Inhalt dieser Nachricht übernommen, da eine Manipulation nicht ausgeschlossen werden kann.
Obwohl alle angemessenen Vorkehrungen getroffen wurden, um sicherzustellen, dass Anlagen dieser E-Mail virusgeprüft sind, wird empfohlen, anhängende Dateien vor dem Öffnen durch Ihr eigenes Virus-Programm zu prüfen, da keinerlei Haftung für Schäden übernommen
 wird, die infolge etwaiger Software-Viren entstehen könnten.
Der Inhalt dieser E-Mail ist ausschließlich für die bezeichnete Person bestimmt. Wenn Sie nicht der vorgesehene Adressat dieser E-Mail oder dessen Vertretung sein sollten, beachten Sie bitte, dass jede Form der Kenntnisnahme, Veröffentlichung, Vervielfältigung
 oder Weitergabe des Inhalts dieser E-Mail unzulässig ist. In diesem Fall wird darum gebeten, sich mit der absendenden Person der E-Mail in Verbindung zu setzen.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140605/0c6d786c/attachment.html>
