[Qgis-user] A discussion: is qgis still affordable in Europe if it violate the Inspire directive ?
Alex Mandel
tech_dev at wildintellect.com
Sat Jun 7 12:35:39 PDT 2014
I understand the issue now. In order to be WMS 1.3 complaint you can
only use what's in the spec.
Looking at an analogy with html specs I find this limitation appalling
short-sighted. It means there can be no innovation testing new features
with the spec unless you manage to get it into the future spec. I find
it hard to comprehend that clients don't just skip tags that fail to
match a known tag. In html land its very common for some browsers to
know some non-standard tags, which are new features in testing to be
proposed or reworked into future standards. IE's policy of only adhering
to the spec and including no experimental tag support has been seen be
web designers as discouraging to any change. Why, because their is no
way to publicly test new ideas.
So from the QGIS side, in order to comply we would need to reply with
only allowed tags if a user requests WMS=1.3.0, we can reply with more
stuff like GetPrint if they don't specify that version. Or perhaps we
have to invent a 1.3.0+ variant specifically for when a user knows it's
QGIS server.
Anyone more familiar with WMS that can shed more light on the best way
to work around this issue and have both compliance and the ability to
add extra features that have no standard equivalent yet.
My point still stands, that EU agencies with this concern should be
funding compliance efforts, not removing funding for lack of compliance.
Thanks,
Alex
On 06/07/2014 12:23 PM, Andrea Peri wrote:
> Hi,
> I need to be more clear.
> My english is tremendous.
> The Interoperability mean to have a small set of operation euals on EVERY
> Server WMS.
> Equals mena same reqeust , same response.
> So when a Cleit WMS send a Request of GetCapabilities, The response should
> be the same from QGIS-server or from GeoServer or From Mapserver.
> The same response mean that every product use the same dialect the same
> tags and so on.
> The XSD OGC is the dictionary that every wms client and server should use
> to know the right language and tags.
> When the QGIS_Server response to a request GetCapbility with an XML that
> contains the GetPrint tags.
> The client wms say "hey what is this ? It is not in the XSD OGC. This mean
> your response is wrong."
> Of course there are some client wms that don0t do a validation of response,
> they HOPE that the response will be exactly as they exected.
> If this is not true. They go in crash or other bad situation.
> Again the resence of a Tag not compliant with XSD OGC will create
> incompatibility.
> Think to a client that will parse the xml response and say:
> ok the GetLegendGraphics tag is passed now there is "this well know tag".
> Instead arrive a GetPrint tags.
> The client wms become crazy.
> Of course QGIS will understand it.
> But this is because you (qgis group) manage it to work.
> But other clients don't know that tag and so they are not able to extract
> all the information from Capabilities response.
> This is a bad practice also because create artiiciosally an incopatibility
> with other products.
> Instead Inspire ask for INteroperability from every product.
> Interoperability don't mean use all the same unique product. (This is the
> microsoft philosophy)
> Interoperability mean All the product must use the same little set of
> command and the response at these command should be compatible
> (interoperable) between all of them
> Actulally this is not true for the response xml of qgis-server at a
> getcapability request.
> Hope to be better explain, now.
> Andrea.
> 2014-06-07 20:49 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>> Hi Alex,
>> The question is not the print capability.
>> The question is to LOST THE INTEROPERABILITY
>> If qgis response an xml that is not OGC complaint it is not interoperable
>> with other product.
>> As example:
>> if an public Administration will eed to do a cascading wms with the server
>> wms of another public administration.
>> The server before of all call for a GetCapability.
>> If the response has a tag proprietary. If fail.
>> This need Not Interoperable.
>> I dont say do not do a getprint.
>> I say remove tha tag GetPrint from the GetCapabilities response.
>> It is not a OGC tag and so that response is not interoperable as requested
>> from Inspire specification.
>> Regards,
>> 2014-06-07 20:36 GMT+02:00 Alex Mandel <tech_dev at wildintellect.com>:
>> On 06/07/2014 11:19 AM, Andrea Peri wrote:
>>>> Hi,
>>>> AFAIK the qgis server is not complaint with Inspire.
>>>> This beacausethe Response to GetCapabilities is not responding to the
>>>> requisite that the OGC will require for it.
>>>> Originally the qgis was simply generate an incompatible response for the
>>>> XSD of OGC.
>>>> The response is ncompatible for thre thinks:
>>>> 1) the GetCapabilities is in the wrong namespace.
>>>> This is a silly question anc could be easily resolved.
>>>> 2)
>>>> The presence of the GetStyle that is dismissed from OGC wms 1.3.0.
>>>> Please notice that the Inspire require the WMS 1.3.0 .
>>>> To resolve this the QGIS groups has copied the XSD of OGC and modifica
>>> it
>>>> to redirect to a different XSD not in the OGC site.
>>>> 3) The presence of a Proprietary tag inserted without any reference to
>>> any
>>>> standard.
>>>> The GetPrint.
>>>> This is not present in any other product.
>>>> My question is for any person of a Public Administration that plan or
>>> are
>>>> funding QGIS.
>>>> In Europe the Inspire directive will ask to promove the
>>> Interoperability.
>>>> The interoperability strategy ask that every produc that allow the
>>> inspire
>>>> directive will speak the same language using the same tags and
>>>> functionality.
>>>> The QGIS solution to add a proprietary tag and to write a own different
>>> xsd
>>>> that overlap the standard OGC xsd will create the presuppost (AFAIK) to
>>>> vilate the Inspire directive.
>>>> If this is true A Public Administration should not use the QGIS.
>>>> This is a realproblem for us that invest many fund on qgis.
>>>> So I like toknow the opinion of other public administration.
>>>> Before still fund a product that seem to violate the Inspire directive
>>>> principles.
>>>> Thx,
>>> To me the question is flipped. What needs to be funded, probably by EU
>>> agencies to ensure INSPIRE compliance of QGIS Server?
>>> It looks like you've put together the list of what needs to be fixed, so
>>> the target should be easier. I am little puzzled about not allowing for
>>> extra functions that are not in the standard. Unless the WMS has a print
>>> standard an extra print add-on doesn't break any expectations. Who
>>> knows, maybe that should be submitted as an extension to WMS.
>>> Note, this should have no effect on funding and usage of QGIS desktop.
>>> Maybe Paolo has good numbers on if EU agencies are funding Server vs
>>> Desktop features.
>>> Thanks,
>>> Alex
