[Qgis-user] LIZMAP ERROR PRINT - HELP!
Andrea Fantini afantini at gmail.com
Wed Jun 11 06:02:40 PDT 2014
I solved part ...... now try to summarize what I have done now with this
demo into lizmap "Montpellier" to print the PDF.
While the same operation done on my project generates me this error in the
log file of apache:
*[Wed Jun 11 00:34:15 2014] [warn] [client 127.0.0.1] mod_fcgid: error
reading data, FastCGI server closed connection  [Wed Jun 11 00:34:15 2014]
[error] [client 127.0.0.1] Premature end of script headers:
qgis_mapserv.fcgi  [Wed Jun 11 00:34:17 2014] [error] mod_fcgid: process
/usr/lib/cgi-bin/qgis_mapserv.fcgi(7515) exit(communication error), get
unexpected signal 6 *
However, I have done these steps:
1. Reinstalled debian 7.5 (LAMP)
2. Added to repo file, those qgis (wheezy main deb http://qgis.org/debian
http://qgis.org/debian wheezy main deb-src)
3. Qgis-mapserver libapache2-mod-fcgid
4. Restart the apache server
5. Install of lizmap (in this case 2.9.4)
Nb: my qgis version is 2.2 and the plugin lizmap is 1.9.7. version of
qgis-map server is 2.2.0.
With these steps, the print function for the demo works, it remains now to
understand why it does not work with my project and I generates the log
file of apache error posted at the beginning.
Thanks for the help
Andrea
2014-06-10 18:05 GMT+02:00 Andrea Fantini <afantini at gmail.com>:
> Hi Michael
> the log file does not exist any mistakes
> what "lizmap" should print to pdf elements are shape-files displayed in
> webgis "lizmap" and the default items in the print template present in the
> project of qgis.
> I also tried to create a simple model with only the element map, qgis from
> the desktop, but the result does not change.
> I hope this problem is not only related to my debian server or the project
> of qgis but also to other people ....
> I hope for a solution :) unfortunately for my case development printing is
> a very imported ..... help!
> thanks
> Andrea
> 2014-06-10 17:32 GMT+02:00 kimaidou <kimaidou at gmail.com>:
> Hi Andrea,
>> This must be a QGIS Server error, as Lizmap only build the GetPrint url
>> and send it to QGIS Server.
>> Could you please be more explicit with the encountered error ? Do you
>> have any log in the Apache error log ? (usually in
>> /var/log/apache2/error.log if you have not changed the default value ).
>> What is the content of the composer you try to print via the GetPrint
>> request ? Does it contains any HTML items, or text items with "display
>> HTML" ?
>> Thanks for your answer,
>> Michael
>> 2014-06-10 13:05 GMT+02:00 Andrea Fantini <afantini at gmail.com>:
>>>  Hello
>>> I developed a WebGIS with lizmap 2.10 but I have a problem with the
>>> print button is Lizmap with version 2.8, 2.9 to 2.10, that is, when I click
>>> on the print button I generate a pdf white. For me it works all the rest.
>>> This problem is also present with the demo present by default in all
>>> versions of lizmap.
>>> My server is Debian version 7.5, this is the package x11-common and also
>>> I also followed this guide:
>>> http://www.itopen.it/2014/03/13/qgis-server-setup-notes/lang-pref/en/ ,
>>> but unfortunately the problem remains.
>>> The project has been realized with Qgis 2.2.
>>> Thank you very much for your support!
>>> BY
>>> Andrea
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140611/de7bfc98/attachment.html>
