[Qgis-user] LIZMAP ERROR PRINT - HELP!
Andrea Peri aperi2007 at gmail.com
Wed Jun 11 08:05:27 PDT 2014
There is available a qgis-server for some online test ?
2014-06-11 10:25 GMT+02:00 Jürgen E. <jef at norbit.de>:
> Hi Andreas,
> On Wed, 11. Jun 2014 at 08:39:11 +0200, Andreas Neumann wrote:
>> It is true that in some cases we need to improve to be more standards
>> compliant. This is a group effort. Everybody can contribute. Removing
>> GetPrint from GetCapabilities, or implementing in a standard compliant way,
>> would help. We could still have it listed in GetProjectSettings.
> It's disputable if the current way is not compliant.
> Changing that might break clients that query the capabilities for the presense
> of GetPrint if we'd applied a (less-disputable ;)) compliant prefix (ie.
> GetPrint to qgis:GetPrint).
> Note that this would only apply to the name of the operation element in
> capabilities, the actual request wouldn't need to changed.
> So it's unclear to me if there are actually any clients that would break.
> At least some already use GetProjectSettings, others might just imply GetPrint
> without checking GetCapabilities - both groups wouldn't be affected.
> The clients that check capabilities would just need to look for qgis:GetPrint
> instead or alternatively of GetPrint - and that should just be a trivial
> change, when 2.4 is deployed.
> Also there are probably not that many clients around that actually use
> GetPrint.
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden               http://www.norbit.de
> QGIS PSC member (RM)      Germany                      IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-user mailing list
Andrea Peri
qwerty àèìòù
