[Qgis-user] Linux build
Volker Fröhlich volker27 at gmx.at
Wed Jun 11 15:39:29 PDT 2014
Am 2014-06-11 23:42, schrieb David J. Bakeman:
> On 06/11/2014 02:20 PM, Volker Fröhlich wrote:
>> Am 2014-06-11 23:15, schrieb Volker Fröhlich:
>>> Am 2014-06-11 22:41, schrieb David J. Bakeman:
>>>> I am running qgis on a Fedora core 18 laptop. I run both the packcaged
>>>> qgis 1.8 and I build the development version.  Recently I wanted to use
>>>> spatialite version 4.1.1 instead of the 3.1 version packaged with
>>>> Fedora.  I successfully built both sqlite 3.8 and Spatialite 4.1.1.  I
>>>> built static libraries to avoid accidentally picking up the system
>>>> shared libraries. When I tried to configure qgis to use the new
>>>> libraries by changing the paths
>>>> SPATIALITE_INCLUDE_DIR/SPATIALITE_LIBRARY/SQLITE3_INCLUDE_DIR/SQLITE3_LIBRARY
>>>> but this didn't work.  The only way I was able to get it to work was to
>>>> modify the FindSPATIALITE.cmake script to the skip the library check
>>>> and
>>>> to add -DSPATIALITE_VERSION_GE_4_0_0 to the CMAKE_CXX_FLAGS.
>>>> My question is should I have been able to just adjust the
>>>> spatialite/sqlite variables or is the way I did it the only way?
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Fedora 18 is out of maintenance! :)
>>> Fedora 20 has 2.2. Will that do?
>>> Volker
>> Wait, Fedora 20 actually has 2.0. I was afraid to push 2.2 because of
>> some issues when opening 2.0 projects. However, you can install 2.2 in
>> Fedora 20: yum --enablerepo=updates-testing install qgis-whatever
> Unfortunately I'm stuck with 18 for awhile anyway.  As I said I was able
> to build but modifying the cmake script seems bad and I assumed there
> was a better way.
> What version of spatialite goes with 20?
4.1.1
>> Volker
