[Qgis-user] Adding Projections
Werner Horsch werner.horsch at gmail.com
Thu Jun 12 09:03:34 PDT 2014
Here some more stuff related to POSGAR 2007 Argentina
http://epsg.io/1062-datum
http://epsg.io/9603-method
http://epsg.io/5349
the problem of adding a new CRS is how to get the right DATUM since I need
to shift WGS84 so as to get D_POSGAR_2007
On Thu, Jun 12, 2014 at 12:03 PM, Werner Horsch <werner.horsch at gmail.com>
wrote:
> POSGAR 2007 Argentina Zone 1 to Zone 7 --> EPSG 5343 to 5349
> The web page isn't completely updated
> Will give a try to your hint, many thanks buddy
> On Thu, Jun 12, 2014 at 11:52 AM, Richard McDonnell <
> richard.mcdonnell at opw.ie> wrote:
>>  Ok, I am open to correction, but you can use Custom CRS under Settings
>>    1. Click add new CRS
>>    2. Give it a name
>>    3. I done a search online for POSGAR2007 and came across this page
>>    http://spatialreference.org/ref/sr-org/posgar-2007-argentina-2/
>>    4. If you select PROJ4 copy the text and paste it into the Parameters
>>    box in Custom CRS
>>    5. You can do a test then at the bottom, inputting the WGS84
>>    coordinates for a known point and press calculate, if the points match then
>>    you are in business!!
>> Regards,
>> Richard.
>> On 12/06/2014 14:57, Werner Horsch wrote:
>>  I'm running QGIS 2.0.1 Dufour on Linux
>> Â
>> I'd like to have POSGAR2007 "Argentina" Projection added on the
>> projection list, can someone give me a hint on this
>>  Thanks
>> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
>> Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140612/c834f854/attachment.html>
